Question about Toys
2001 Gator HXP cranking no start I have checked fire, fuel and compression, all that is good is there something else that tells these when to fire.i have tried starting fluid and still wont hit.
  • 46 Answers
SOURCE: 2001 sebring will turn over but will not start
Most Chrysler cars do have an anti-theft system that can cut out the engine.
I would call the service department, with your VIN handy, and see if yours was equipped with one, and what you need to reset it.
If that isn't the problem, your EGR valve might be bad, or the sensor for it. I've seen a lot of cars where if either the valve itself, or the sensor are malfunctioning, the car won't run properly.
I would also check your MAF and IAC, as those can cause the car to not run.
If you can, get an OBDII code scanner, and pull the codes from your car, they might give you a more specific place to look. (Most parts stores will let you take one home, you put a deposit down, and get it back when you bringthe scanner back to them)
Posted on Dec 04, 2008
SOURCE: 2000 gmc jimmy wont start
I also had this problem with mine. There's a main power cable that runs to the battery. The bolt was completely corroded, so there was no connection = no power to start the truck. Check that, it'll cost ya less than 5 bucks to fix.
Posted on Jan 16, 2009
  • 188 Answers
SOURCE: 2000 Chevy Blazer Cranks but wont start...
What about the fuel filter????? Have you changed it out??? If you can spary something like a started fluid, that means it is a fuel problem. My last check, it has to be above 50-psi on the fuel pressure to make it run right. I had 35psi, but whould not get over 30mph or down hill maybe 45mph. Check both filter & pressure, but check pressure with a New fule filter!!!!
Posted on Feb 09, 2009
  • 35 Answers
SOURCE: Car won't start/fire up
Check all the grounds sounds like what i had on my truck. It took a good mechanic to find it but it ran after.
Posted on Feb 10, 2009
steve_lima
  • 181 Answers
SOURCE: wont start
remove the muffler and see if there is scoring on the piston.if ther is the saw needs piston and cylinder.sound to me that there is a lack of lubercation to the cylinder
Posted on Feb 11, 2009
Why won't my car start. It cranks over but won't fire up. It's getting fuel.
Hi you need to check for fuel pressure and volume then injector pulse . check for spark , check timing and compression.
If you dont find injector pulse or spark , suspect your cam and crank shaft position sensor.
Hope this helps a bit ,
kind regards Faldih Higgins
Jan 22, 2016 | 2001 Chrysler Sebring
2001 nissan sentra cranks but wont start
Dean, it looks like your on the right path ,with all 3 things as you stated it should do something, did you try a little starting fluid , you could use a timing light to check for good steady spark . what other kind of work have you done to it ? re check your work ,when you did compression test how did the plugs look =clean =soaked in fuel = nothing at all? Woody.
Aug 27, 2014 | 2001 Nissan Sentra
2001 1200 sportster cranks and backfires, carb and fuel good, could it be crank sensor?
Wasted spark system. If fuel and electrical is all good/correct it is often the case in these symptoms that motor cycle spark plugs that although looking good and firing outside of the engine are breaking down and will not fire under compression pressures on a power stroke but will fire unburned fuel on the unpressurized exhaust stroke when the plug again fires in a wasted spark ignition system and when so firing the result is a backfire, usually quite loud.
Jul 23, 2014 | 2001 Harley Davidson XL 1200 C Sportster...
I have 2001 dodge durango will crank and start for about a second changed cam sensor ,crank sensor,pcm,fuel regulator and still wont run its getting fire and compression and fuel but still wont run any...
Check starter relays & fuses check all fuses for electrical modules
drivers side inner finder electrical pannel for starter check all fuses and relays
Aug 15, 2013 | 1997 Dodge Intrepid
2004 John Deere Gator CS
Hi, although i dont know what a gator cs is i would suggest you first check that your valves are opening to actually let your fuel mixture into the engine. If the valves are opening / closing at the correct time you need to check compression on all cylinders. you may have sticky rings or worse.
Sep 17, 2017 | Motorcycles
89 camery no start , has fuel p.s.i. , injectors fireing , spark on all plugs , compression even across
Have you checked cam timing?If it has jumped a tooth or two it will not start.
Jun 18, 2017 | 1989 Toyota Camry
2001 chev s10 v6 after a head gasket replacement the truck wont trun over and no fuel to the intake.
Hi, your starter circuit is pasted below. Check the crank and ignition fuses in the box under the hood. If those are good, see if the solenoid will jump by connecting the hot terminal to the start terminal as indicated in the following post: http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over
If the engine will crank, the problem is in the start circuit--ignition switch, start relay, or safety interlock. If it will not crank, suspect you are a missing ground strap. Since you had the top off the engine, this is the most likely problem, depending on where you ground attaches to the engine.
As for the fuel pump, this could also be a ground issue or a fuse. Suggest we get the engine cranking and then worry about fuel if the pump is still not coming on.
Can you check the fuses and jump the solenoid (tranny in park, please) and then get back to me with results?
Mar 31, 2011 | Chevrolet S 10 Cars & Trucks
My 90 acura integra wont start it turns over but wont fire i changed the distributor,and spark plugs,i am getting fuel but it just cranks and cranks but wont start,the cause i dont know was driving down...
Well, something is missing. Your engine needs fuel, ignition, and compression to run. You need to findout which of these systems is malfunctioning before anybody can tell you why your engine won't start.
If there is no spark, I would check the ignitor in the distributor first. There are other possible causes, but this isthe most common.
If there is no fuel, I would suspect a bad fuel pump. (you can check this by spraying a SMALL amount of starting fluid in the intake and see if the engine fires.
If there is no spark and no fuel, I would suspect a broken timing belt.
Feb 05, 2011 | 1992 Acura Integra Hatchback
My chevy s10 2001 turns over but does not start its not getting gas to injectors
Well you need fuel to the injectors, a spark, compression, air and a signal to the injectors to fire for the engine to start.
So if you've got fuel, make sure you have spark to the plugs, the air filter is not clogged, compression is above 120, and the crank and cam positions sensors are good.
Jan 21, 2010 | 2001 Chevrolet S-10
Truck will crank but won't start, checked fuel tank switch and it works, you can hear fuel pump come on and truck still won't start
check the fire to the spark plugs first,if they fire good check fuel pressure,if good check compression especially if it's a 300 6 cyl they can almost completly loose compression and sometimes no smoke or any thing.that pretty well covers all bases gas pressure,fire,and commpression.if low compression check timing they had plastic on the outside of the gears it breaks and falls off then time jumps,warning i've seen some vehicles still show decent compression even out of time just depending on the position of crank and cam.hope it helps
Jul 04, 2009 | 1990 Ford F150
Toys Logo
300 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
