Question about Epson WorkForce 633 All-in-One Inkjet Printer 15 PPM, 5760x1440 DPI, Color, Wi-Fi, PC/Mac
Had paper jam, clear the paper and now there is a loud crunching sound and the printer will not print at all
  • 30 Answers
Sounds like you have paper jammed in the gears , send printer to repair they will probably take it apart and clear the paper , then the gears have to be working OK
Posted on Apr 19, 2015
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Tip
Printing tips for paper jam
<b>ThePaper Jam</b> Wehave all had this one happen. You are printing merrilyaway when all of a suddenyou hear that distinctive crunch of paper gettingeaten by your printer. Youimmediately cancel the print job, leap from yourdesk and flip open the printer."Ugh," you say as you notice the crinkled edgesof paper wrapped around godknows what. Okay, so you have found the problem,but what do you do? Thebest way to remove a paper jam is to gently pull thepaper in the direction ofthe paper path-with power off, of course. Whateveryou do, don not pull thepaper backwards. You could damage your printer foreverby doing so!
on Mar 31, 2011 | Office Equipment & Supplies
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Jammed cartridge error froCanon MultiPASS MP730 All-In-One InkJet
You can open up the device and look inside. You'll prob ably find a jammed peice of paper or a paper clip or some obstacle inside jamming either the rollers or the track for the print head, or both.
Nov 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jams after printing and will not exit top output tray
sounds like the gear drive assy faulty.take it back to where you purchased.Samsung should cover under warranty.
May 25, 2009 | Samsung ML-2510 Laser Printer
Kycocera fs2000d
Sounds as if the fuser unit has a damaged gear.You will need to call out a technician.
May 01, 2009 | Kyocera FS-2000D Laser Printer
Paper jam with out paper
This is almost certainly a broken latch on the right of the carriage - it should get pushed forward by the left back edge of the cartridge mechanism as it reaches the right side. There are other examples of this described in many similar posts on various sites - including some with photos. Try and find another psc all-in-one and look at it. I have the same problem, and have 'mended' the latch so that the paper error disappears and it prints, but I have not yet solved the loud clicking
Richard
Mar 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Canon Pixma MP530 clicking
it is nothing to do with a phone jack, trust me this sounds like internal crunching and munching... but as reported by the others, no jams, no printing errors, just loud clicking and clunking!
Feb 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Epson WorkForce 633 All-in-One Inkjet Printer 15 PPM, 5760x1440 DPI, Color, Wi-Fi, PC/Mac Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
