Question about Chateau Dryers
Broke the glass cover and want to purchase a replacement
Chateau Deville 2 light walnut semiflush mount
    Genius:
  • Chateau Master
  • 1,617 Answers
What is the make/model of fan?
Posted on Apr 20, 2015
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
My 2005 DeVille won't come out of park. This just happened today. I drove it early this morning. I went to get into it this afternoon, I started the car, stepped on the brake and the shift lever won't come...
Have someone check if your brake lights are working
The brake light switch and shifter lock are usually one switch
If your brake lights are not working your brake switch needs to be replaced
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
Jan 02, 2011 | 2005 Cadillac Deville
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
    This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
    1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
    1. Remove one screw retaining rear hi-mount lamp (13A613).
    1. Lift edge of rear hi-mount lamp and pull away from back window glass.
    Installation
    1. Follow removal procedure in reverse order.
    1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
      Hi-Mount Rear Lamp
      Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
    Jun 05, 2010 | 1997 Ford Thunderbird LX
    I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
    I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
    It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
    May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
    The glass of our sunroof broke. How do we replace
    Hi there;
    Hey broken glass in the sunroof is not as big of a deal as you might think. The glass is available from Lexus & concidering where it is coming from it isn't that expensive. When you get the new piece of glass you'll see how it is bolted on. You simply rmove the trim around the glass mount with a flat pry bar & undo the mounting bolts, noting the alignment shims befor you remove the old glass mounts & be sure to put them back in where they come from. Take you time & pay close attention to those things & you will be able to change it with out an issue!
    P.S.; you may also be able to find the glass from a local auto wreckers for a fraction of the dealer price.
    Good Luck Hope this helps.
    Farrout!
    Mar 09, 2009 | 1996 Lexus LS 400
    Replacing side view mirror cover on 200 SAAB 9-5
    I need a complete passenger Side Mirror (2nd Hand) N-95 (S Reg) contact 07966 366195
    Jan 26, 2009 | 2000 Saab 9-3 Viggen
    BROKEN GLASS COVER UNDER NIGHT LIGHT
    SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
    May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Broken glass light cover...
    you should be able to use the unit without a problem,in between the panels where the light is theres insulation.you can try northernparts.com they may have a replacement cover for your unit.
    Dec 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
    Dryers Logo
    Top Chateau Dryers Experts
    Dan Webster
    Dan Webster
    Are you a Chateau Dryer Expert? Answer questions, earn points and help others
