Question about Garden
I have a john deer stx38 fuel shutoff solenoid is bad can I bypass this
  • 1,169 Answers
Unless the solenoid is shorted or opened electrically; or physically damaged have it ultrasonically cleaned. No chemical dip as it will damage the enamel coated wires.
Removing and bypassing can cause exhaust system damage from raw fuel igniting in the exhaust during shut down.
Posted on Apr 19, 2015
  • 1 more comment
  • Cathy White
    Cathy White Apr 19, 2015
    Can I bypass this if so what do I do with the wiring part
  • Eugene Rounds Apr 19, 2015
    Go by John Deere and pickup PN M120421 and M77219. Simply disconnect the wire and tape securely of the harness. Remove the solenoid and install the parts fore mentioned.
  • Cathy White
    Thanks eugene thats exactly what I was looking for
  • Garden Master
  • 2,478 Answers
I unhook wires to the solenoid, installed fuel shut-off valve. When I shut-off engine close the valve.
Posted on Apr 20, 2015
  • 2,428 Answers
Why do you think its the fuel shout off solinoid you can test that with jumper wires right off the battery if it moves it works .
Its sounds like the problem is no fuel to the carb mabay a basic inspection of fuel delerivery pumps filters air filter it is a tractor .
Then look at at the carburator drop the float bowl see what you have in the bottom of the bowl if its not clean neighter is the carb'
    Sergeant:
  • Garden Expert
  • 187 Answers
The John Deere STX38 comes in 2 models, the yellow deck and the black deck. Further you did not say which engine model you have on your machine. Therefore the following answer is just a generalization. This may or may not work for you.
Diagnosing the Fuel Shut Off valve:
  • Assuming the battery is good and fully charged
  • Assuming the Key Switch is working.
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. If you hear this click your fuel solenoid is functioning electronically. It could still be experiencing issues inside the carburetor. Perhaps there is some varnish, silt or other trash keeping it from working. This will require a physical examination.
The following is an "out of carburetor" electrical check up.
  1. Remove the Solenoid.
  2. Connect one jumper wire from a terminal to the positive battery post.
  3. Connect a second wire from a terminal to the negative battery post. The solenoid should retract.
  4. Remove one jumper; the solenoid should spring back out.
It is likely possible to disable it inside the carburetor bowl. These shut offs use a little electromagnetic motor to push a plunger up and down. The plunger seals off the fuel inlet. Theoretically you could physically disable that process. You could for instance, cut the plunger head off the solenoid.
A better, albeit more expensive, option is just to replace the solenoid. You did not say but you likely have a Kohler engine. Not knowing your exact engine model I can't absolutely specify your replacement part. However you may need this part # 12 757 28-S. These typically run about $100.00
The John Deere part number is AM128242. You can get this on Amazon for about $80.
Green Parts has this kit for $75
http://www.greenpartstore.com//search.asp?keyword=AM128242&search.x=14&search.y=13
You have to specify your exact engine model to find the exact replacement part.
GreenPartStore Parts for John Deere Lawn Tractors John Deere Lawn Garden...
  • 1 more comment
  • Cathy White
    Can I bypass this If so what do I do about the wiring part
  • Kprime
    Kprime Apr 19, 2015
    You can just take the solenoid out and put a machined bolt (with a fiber washer) back in the hole. You might also remove the solenoid, pull out the plunger, then screw the solenoid back in. At this point, just reconnect the connector; it’s a handy place to put it and it will no longer have any effect on the running of the machine. Another option is to just wire tie the connector out of the way. No other electrical component relies on this connector or the functioning of the solenoid. The only downside to bypassing this device is possible engine backfire at shutoff. When you turn the key off, this device blocks any further fuel from going into the carb. Without it you may get extra fuel sucked through the cylinders. With no spark it doesn’t burn in the cylinder. It then explodes when it hits the hot exhaust. Eventually that will damage your exhaust system. I am not sure the trade off of the money saved today is worth the long term life of the engine. For my own equipment, I wouldn’t do it. Other than that problem, there is no other effect on the running of the system. You will of course be bypassing one element of the safety shut down system. That’s your liability element.
  • Kprime
    Kprime Apr 20, 2015
    What John says in his answer is a point to consider. Do you really have a bad solenoid or are you having fuel problems that may be something else entirely. If you want to repost your question as unknown fuel related problems, I will provide an entirely different answer. Be sure to include your engine model and meter hours.
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
daneinwv
  • 124 Answers
SOURCE: John Deere stx38 belt diagram
My name is Dane and I am going to help you solve your problem.
Here is a pic of the belt diagram for that mower.
I hope I
Posted on Dec 22, 2010
I have a john Deere stx38 yellow deck Kohler motor does this mower have any fuses that has anything to do with getting fire
Hello I'm wade No it doesn't! It is all ran by key switch. If you can remove air filter and spay starting fluid in engine if it starts then you having fuel delivery problem. Fuel shut-off solenoid usually sticks not causing fuel to get into engine and that solenoid is what kills the engine when key gets turned off. If you have any further question I'm here to help. Wadembly@aol.com
May 07, 2015 | John Deere Garden
John deere 6715 tier 2 wont crank
a bad safety switch will shut off the solenoid most likely the one on the clutch/brake pedal
Jun 27, 2012 | Garden
I have a john deere stx38 and it has no spark and wont fire but engine turns over
Check the shear pin in the flywheel, replace if bad, should cure your no spark problem
May 28, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
Garden Logo
436 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
