Question about Air Tools & Compressors
Why won't it fire? - Air Tools & Compressors
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hey,
Im a newbie to the page but work on bostitch every day at work. So, assuming that you have at least a 100psi on the compressor and everything is hooked up. still no fire? then disconnect your air from the gun, make sure the safety arm is working properly and is making contact with the trigger. flip it upside down with the air off and push down the trip you should see a small bar slide behind the trigger an hit a flipper that in return allows the button on the trigger to go down. sometimes the trip gets misaligned and have to take off the guard to adjust it. not too bad. write back if you have more concerns. Thomas Industrial Supply Inc. Schofield, WI we are on the net. I rebuild guns everyday mostly bostitch,spotnail, and a variety of other guns.
good luck call if you need assistance. 715 359 4124 we'll sure try to help.
Posted on Nov 16, 2015
  • 3,519 Answers
Hi Don:
There could be several different causes so let's try the easiest step first.
SAFETY FIRST! Disconnect from the air supply.
- Check for a nail jammed in the discharge slot. Some guns have cap screws that hold the assembly together. Take it apart (keep the pieces organized and in sequence) and you will probably find where it is jammed. Clean, lubricate, re-assemble, insert some nails, connect air, test, disconnect air, Happy happy!
- Piston not retracting fully. Same routine as above only include dismantling poston assembly.
Posted on Apr 19, 2015
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
91 Cherokee will crank but won't fire. Replaced
how much is the RPM showing in the datatlogger while cranking?
Dec 03, 2012 | Cars & Trucks
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
Replaced igniter and valve assembly still won't fire up?
check the door locking mechanism, if the door isn't giving a signal that the door is closed it won't fire up,
Jul 21, 2011 | LG D2526 Gas Dryer
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Air Tools & Compressors Logo
309 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
