Question about Dishwashers
ON MY MDBH979SAM0 THE START/RESUME LIGHT IS BLINKING AMBER HOW DO I REPAIR
2 Suggested Answers
  • 188 Answers
SOURCE: blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
Helloi am having problem with dell t5400 presionwhen i start my pc and show my desktop few minutesautomatically turn off and orange light blinking do you tell me what the problem with My t5400 precisi
The only blinking orange light is located on the Network RJ45 connection
If you're talking about the Power light on the Front panel:
If the Power light is blinking green the computer is in a sleep state: The computer is in standby mode. Press a key on the keyboard, move the mouse, or press the power button to resume normal operation.
If the Power light is blinking amber indicates that an internal power problem might exist; The computer is receiving electrical
power, but an internal power problem may exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that all components and cables are properly installed and securely connected to the system board.
You can find the User Manual here Product Support Dell US
May 06, 2014 | Dell Computers & Internet
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon Office Equipment & Supplies
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Blinking Lights
do this to reset your printer:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
Jul 24, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
Oct 06, 2008 | HP DeskJet 1280 InkJet Printer
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
