Question about Dewalt Air Tools & Compressors
How do I take apart a dewalt d5141 compr3ssor?
  • Dewalt Master
  • 1,805 Answers
This number is for the D20114 its the safety valve that can not be set to a max basic pressure .
its strange but its not adjustable it can be defect i have one time the same the experience there is not a adjustable Pressure Switch on this model , the moast compressors have a 8 to12 bar adjustable.pressure switch.
Very important This safety valve gives an electronic brake between the pump and to a end of top about 10 bar . if its not switching off then a drain valve opened . and blows all the air out. (but only over 10 bar ) the max pressure on the tank , the moast tools are working on a pressure from 6 to 8 bar.
Checking Safety Valve
WARNING: Risk of bursting. If the safety valve does not work
properly, over-pressurization may occur, causing air tank rupture or
an explosion.
Before starting compressor, pull the ring on the safety valve to
make sure that the safety valve operates freely. If the valve is
stuck or does not operate smoothly, it must be replaced with the
same type of valve.
Draining Air Tank (Fig. 1)
WARNING: Risk of unsafe operation. Risk from noise. Air tanks
contain high pressure air. Keep face and other body parts away from
outlet of drain. Use safety glasses when draining as debris can be
kicked up into face. Use ANSI S12.6 (S3.19) ear protection as air flow
noise is loud when draining.
NOTE: All compressed air systems generate condensate that
accumulates in any drain point (e.g., tanks, filter, aftercoolers,
dryers). This condensate contains lubricating oil and/or substances
which may be regulated and must be disposed of in accordance with
local, state, and federal laws and regulations.
1. Ensure On/Off switch (A) is in the OFF position.
2. Move compressor into an inclined position so drain valve (H) is
at the lowest point (this will assist in removing moisture, dirt, etc.
from air tanks)
3. Place a suitable container under the drain valve to catch
discharge.
4. Grasp black lever on drain valve.
5. Slowly rotate lever to gradually bleed air from air tank.
6. When air tank pressure gauge reads 10 PSI (275.1 kPa), rotate
valve to the fully open position.
7. Close drain valve when finished
Posted on Aug 05, 2015
My dewalt impact gun dcf885 when I press trigger the motor starts then dies
Mick, this could be a sign of a worn out/faulty motor, mine did this, ripped it apart and it was the motor. Yours may still be under 3 year warranty if you can find your receipt.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeWALT DCF885C2 Type 1 20V Impact Driver Parts
http://www.mmtoolparts.com/store/dewalt-impact-driver-parts
http://www.dewalt.com/en-us/legal/warranty/general-warranty-information
DEWALT ServiceNet
Jun 13, 2016 | Dewalt Drills
I have a DeWalt DC925 type 1 hammer drill,took it apart to repair switch and clean. Four pin bearings fell out,I don't see them on a parts diagram,where do they go ?
You will find them in the transmission, remove the metal cover and they will be located just under it - sounds like it is either the gear posts or the clutch cams on the nose side of the transmission DeWALT DC925 Type 1 Hammer Drill Parts
Mar 23, 2015 | Dewalt DC925 Cordless Drill
Had the Dewalt DC988 transmission fall apart on me, and despite my best efforts, can't get it back together. Does anyone know of any diagrams I could follow or advice? Thanks, Tom.
Go to servicenet.dewalt.com and enter your model number in the search window on the left where it say's find parts. You'll see a list of parts by description and link to an exploded view.
Oct 01, 2011 | Dewalt 18 Volt Compact Drill Kit
I have a model 55270 dewalt compressor,serial #20813 I'm looking for manual and age.It shows date 200449-49
The link below takes you to Dewalt parts/service section. Here you will find manual and parts. The dewalt service center will gladly tell you the date of mfg.. Just call them with model, type and serial#. Good luck with your compressor.
http://servicenet.dewalt.com/Products/Detail?productNumber=D55270
Jun 30, 2011 | Dewalt D55270 gas powered air compressors
How to replace brushes in dewalt dw959
Simply Google "how to replace 18v dewalt drill brushes"
You will get three youtube videos on how to do it right at the top of the page...
heatman101
Sep 08, 2010 | Dewalt ; 18v 1/2" Compact Drill Driver...
How can I disassemble a Dewalt keyless cordless drill chuck? I mean take it apart, not just remove it.
depending on the chuck it would take special fixtures to press apart, and unless you are very good with tools you would damage it beyond repair. I have never taken a keyless apart and tried to repair and put together, I have on the other hand done the same with the keyed chucks.
Dec 13, 2009 | Dewalt Drills
Transmission fell apart. Looking for blueprint to reassemble.
The transmissions come as an assembled unit and there are no drawings for the internals. If you can find an old drill that is no good, use it as a guide.
Hope this helps
Apr 13, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Air Tools & Compressors Logo
182 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
