Question about Garden
I'm removing the engine but need to take off the pulley assembly - which includes the electrical drive selector - under the mower floor. How do I get this pulley assembly off the draive shaft?
  • Eugene Rounds Apr 19, 2015
    Hi Ffaffer , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the make and model of the mower?
  • Ffaffer
    Ffaffer Apr 20, 2015
    Sorted! Thanks.
  • 682 Answers
Normally you take the bolt out holding it to crankshaft (center of pulley). Then pull the pulleys off the end.
Posted on Apr 20, 2015
Testimonial: "Thanks. It was actually very obvious and simple. I'd removed the bottom bolt suggested but pulley would not slide off shaft - until I unbolted the small retaining bracket that didn't seem to be holding anything - then they just slid off.Getting it back together after engine rebuild may be fun!"
2 Suggested Answers
bbreton
  • 437 Answers
SOURCE: need to remove pulley from spindle to replace
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Ignition/no spark on ford GT85 riding mower with a kohler M18QS gas engine. I need the electrical schematics for diagnostics.
follow this steps and fix it. GOD BLESS YOU
If grass is poorly or unevenly cut, try mowing at a slower speed and adjusting the engine speed with instructions in your owner's manual. Scrape away any dried grass and other debris caked under the mower deck. Sharpen or replace dull or bent blades 0fbc95da-10ce-4268-a804-bcc52ffe7dcf.jpg. Check and replace a worn belt.
If the V-belt slips or comes off during use, clear any debris in the belt area, adjust the drive-belt tension (see below), or have the belt replaced. Adjust and tighten pulley fasteners or have a service center replace worn parts.
If the belt squeals or wears excessively, adjust the drive-belt tension (see below) and look for obstructions around the belt. If that doesn't work, take the mower in for professional service.
If the mower vibrates excessively when the clutch is engaged, scrape away any debris accumulated under the deck. Balance the blade and replace the blade if needed. If that fails, adjust drive-belt tension (see below). If you find that the drive belt, pulley, or other belt-drive part is damaged, consider having it replaced by a professional.
If the mower is hard to shift or doesn't move when the clutch is engaged, adjust the drive-belt tension (see below). Also make sure the mower is lubricated according to the owner's manual specifications. As needed, have the mower serviced for damaged or maladjusted clutch/brake pedal linkage.
If the engine doesn't start, loses power, or dies during use.
Replace a recoil starter rope:
  1. Disconnect the spark plug cable for safety.
  2. Disengage the throttle cable from the housing and remove the housing as needed to access the starter.
  3. Remove the handle from the rope, which is often held in place by a knot or retainer pin.
  4. Unfasten the other end of the rope from the starter using pliers or a cutter as needed.
  5. Knot the end of the replacement rope.
  6. Tighten the pulley counterclockwise all the way, then back it off two turns and hold it firmly.
  7. Thread the unknotted rope end through the pulley hole.
  8. Thread the rope through the housing hole and pull it taut.
  9. Slowly release the pulley, allowing the rope to wind around the pulley.
  10. Attach the handle and reassemble as needed.
  11. Reconnect the spark plug cable.
Replace a recoil starter spring:
  2. Remove the housing and the spring cover.
  3. Carefully remove the rope from the pulley to release spring tension.
  4. Remove and replace the spring as recommended by the manufacturer.
  5. Reinstall the pulley, rope, and housing following the instructions above.
  6. Reconnect the spark plug cable.
Nov 12, 2013 | Garden
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Oct 15, 2009 | Mtd Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
