Question about Car Audio & Video
My Mach 1 electric scooter Is a 2 pin European plug so what fuse sicker would I need to get without them burning out 13 amp plug ok or .
  • 3,194 Answers
It is usual practice to cut off the European plug and fit a British 13 amp plug even though adapters are available. The charger isn't likely to require much current so fitting a 3 amp fuse should be ok. If you discover the plug or the positive pin is becoming warm after some time you could increase the fuse rating to 5 amp, though I doubt it will be necessary.
Posted on Apr 19, 2015
Dyson upright vacuum with kinked cord kept stopping. There was a loud bang and smoke and the vacuum stopped. Has the motor blown up, or can it be repaired?
This happens a lot the supply cable bending or damaged shorts out causing smoke and a bang if fitted with or backed up with a high amperage fuse .
check length of supply cable if you find damage/ burning smell,
either replace cable, or you could fit a inline rubber socket and plug by cutting out damaged part of cable and fitting female part of plug first into supply cable 1. then on the vacuum side of cable fit the male part of plug 2 . supply 1. -----o o----------2.--- vac
using insulation tape if you like you can tape plug and socket together to stop it pulling apart, normally cable damage will not damage the vacuum cleaner. and fit the correct fuse rating for the machine 1000 watts at 240v divide 240 into 1000 =4.166 amps
so with a 1000 w load you do not need a 13 a fuse fitted 6 amp fuse should be ok. or go online and see what is recommended re fuse size for appliance ,
Nov 12, 2016 | Dyson Vacuums
I just moved to France and brought my Juki TL-2010Q from the USA. I plugged it in with a European adaptor and it blew the fuse? Is it fixable? Where do I get a replacement fuse? Thank you! Suzanne
Did you mean an 'adaptor' (as in two-pin to 3-pin) or a transformer ?
It is a DIFFERENT electrical system in Europe to the USA.
The USA is 110v and Europe is 240 or 220v. The machine is
probably burned out. You would need to take it to a dealer to be checked. You can ONLY use USA electrical equipment with a TRANSFORMER, so that it can function on the different European electrical system. Good luck !
Sep 12, 2016 | Juki Sewing Machines
Celebrity x charging fuses
Hidden under the floor mat and hatch, you'll find two high amp fuses that Pride say don't exist! - they do. Be careful with the rubber mat lugs they deform and are tricky to reseat.
the fuses are standard car fuses. It's busually the red 10 Amp fuse that's blown.
the cause of the problem may possibly be the three pin XLR cable/ plug.
Apr 21, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Lynx l3 dead
hi, Are you sure then battery box is fitted correctly ? you need to make sure the battery box is supplying a voltage to the scooter, there is a fuse located within the box however it rare to blow this unless you used a higher amp charger , normally more than 5 amps, this type of charger would be for a 8 mph scooter etc.
IF you have access to a electrical meter plug the two probes into the outside pins of the charger socket , do not allow them to touch, measure the voltage, no voltage then the fuse has gone or a contact has come off the battery
IF you located anywhere near me SS16 then testing is free.
Regards
www.gewizrepairs.co.uk
Dec 27, 2012 | Invacare Supply Group Invacare Lynx L3...
I have a 2001 ford focus. The car shut off on it's own and it turns out I blew the 30A ignition fuse. When I replaced it, the car worked as normal for about 5 seconds before it blew again. Where should...
Wow! You just passed your first course in "Auto Repair 101". I don't have to explain it to you like I do 90% of the folks out there that think that a problem with their electrical circuit is caused by a fuse. I am constantly preaching that FUSES are NEVER the cause of a circuit failure. Blown fuses are ALWAYS the RESULT of a circuit failure. I tell them that the fuse is blown because it has given its life to keep your vehicle from burning to the ground. I go on to say that replacing that fuse without finding and correcting the condition that caused it to blow in the first place will only cause another fuse to have to give up its life to stop your car from toasting. In such cases, the first fuse will have died in vain. But you already figured that one out by yourself!
>>>>Let me see if I can help you....
Fuse #8 (Ignition), 30 Amp, located in the Battery Junction Box (under the hood) feeds the circuit which goes to Pin #5 (RED) in connector #13 at the Central Junction Box (Under left side of dash). Here, it provides the power source for the starter relay. It also branches off at this point and continues to the ignition switch. (A very likely place for your problem to be located)
From the ignition switch it returns to the Central Junction Box (CJB) via 5 separate circuits.
1. From Pin #7 on the ignition switch (Grey/Black) to Pin #4, Connector # 17 (CJB)
2. From Pin #6 on the ignition switch (Yellow) to Pin #6, Connector #17 (CJB)
3. From Pin #1 on the ignition switch (Green/Yellow) to Pin #1, Connector #13 (CJB)
4. From Pin #3 on the ignition switch (Black/White) to Pin #14, Connector #11 (CJB)
5. From Pin #5 on the ignition switch (Red/Black) to Pin #10, Connector #11 (CJB)
It also branches out from Pin #3 at the ignition switch and runs to Pin #2 in Connector #931 at the Gearshift Lever Unit.
At the Central Junction Box, it feeds several other (smaller) fused circuits. Your problem will not be beyond this point. (If it was, the smaller fuses would be blowing, not this one)
If there are any aftermarket accessories (i.e. Alarm, Remote Start, Stereo Amplifier, etc.) tied into any of these ignition circuits, I would try disconnecting them first, unless it is very obvious that there is something else wrong like a burned ignition switch connector.
The circuit from the Starter Relay to the Starter could also be the problem, but not very likely if the engine was running at the time that it blew.
Feb 01, 2011 | 2001 Ford Focus
230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Regards
GeWiz.
Dec 10, 2009 | Electric Mobility Mobility Electric Power...
No right channel output after fuse blow out
Sounds like the power transistor(s) on that channel burned out. Needs service.
May 04, 2009 | Audio Players & Recorders
Need help, put in new mother board and need help putting in usb connection to front of computer have mach speed motherboard, does anyone have a map for this?
There are probably cables coming from the front of the computer. On the motherboard, you will see 2 or more groups of pins where these cables go. Unfortunately, sometimes the cables don't have a single plug, but have one plug that has 3 holes and then 1 that has one. Many times, too, there are 2 sets. So--let's see if this helps:
The pins will be labled something like USB and then several numbers.
The pins look like this ::::. (hope that shows up OK)
If your usb cable end has one large (3-hole) plug and one small, the large one goes over the first 3 pins from left to right. The one on the left is labeled VCC. The separate plug goes on the 4th pin.
You can use the top row of pins or the bottom. Nothing goes on pin #5 on the bottom.
Does this help? If so, rate it accordingly, please.
Apr 19, 2009 | Mach Speed MS945G-GLV Motherboard
HAVE A HOVEROUND
Carefully read across two pins, without shorting to the case or other pins. You should have 1 hot, one ground, and usually another ground that acts as a charge inhibit to keep the scooter from driving while charging. I would expect to see around 27 Volts DCX on the output, maybe more without a load attached (battery)
Jan 25, 2009 | Electric Mobility Power Electric Scooter...
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
