Question about Homelite Garden
Where can i get a replacement bar oil cap for a homelite xl chainsaw
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If is out of stock, try Jacks Small Engines. You'll need your model and serial number for either place.
Posted on Apr 21, 2015
  • 3,957 Answers
Posted on Apr 19, 2015
Homelite chainsaw ut10560A leaks bar oil, how do I replace the oil tank and check the pump and oil lines?
Would say the tank is not problem, believe this model may have a check valve In cap, would replace or repair cap and check lines for holes. Maybe this drawing will help.
Nov 18, 2017 | Homelite Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
Jan 21, 2014 - Uploaded by
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
? 6:38
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
Homelite/ (authorized parts supplier) - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Feb 27, 2010 | Homelite Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Garden Logo
268 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
