Question about Garden
How do I stop the engine cutting out when I apply the cutting deck
  • 1,169 Answers
You have an operator present switch or wiring failure. IE Seat switch
Posted on Apr 19, 2015
2010 subaru forester engine cuts out
consider this
when at the stop lights , you will have your foot on the brake as it will still be in drive or in gear and you don't want the car to move
a simple test is to apply the hand brake to stop the car and don't touch the foot brake
if it idles ok but cuts out when you apply the foot brake , replace the brake booster as it has a vacuum leak that is causing the problem
you can do this test in the garage by starting in neutral and allowing the engine to idle , then apply the foot brake
iof it dies it is the booster
Oct 01, 2016 | 2010 Subaru Forester
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Mod# 917289450 54" deck
Next time as the engine begins to stall, loosen the fuel cap.
If the engine runs smoothly, clean the vent holes on the gas cap.
Gary
May 04, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Treadmill get stop with a jrk whn power gets a cut..
Sounds like the wax lubrication has finally boiled off the belt the easiest way eliminate this problem is to rewax the deck. You may purchase this @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Now the fun part to apply this product you must first get the treadmill and walk on it for about 5min to heat up the deck, then stop the unit with your product go to upper third of the belt lift edge of the belt stick the nozzle between the belt and deck squeeze the bottle approx. amount 1 tbs of wax to the center then get back on the treadmill and walk for 10 min this is to heat up the wax so that belt will act like a wick to absorb wax! This should be done every 3 months or so. Their a catch if this does fix the problem you may be investing in a new belt and possible and new deck. Hope this take of it!!
Feb 02, 2010 | Precor 9.21 Treadmill
PTO Issue
It sounds like you got the cable to tight. The brake cable applys the brake to the pulley to help stop the blades when PTO is disengaged. With it being tight it might be applying the brake and that is the reason your blades are not running at full speed. If you keep using it that way it will wear out your brake and possibly damage a pulley. I suggest you loosen the brake cable or replace it with a new one.
Aug 31, 2009 | Garden
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mazda Familia Interplay 1991 - engine cuts out when brakes applie
is the over drive mode on an automatic on when the hold light apears or does this mean it is off?
Feb 01, 2009 | 1991 Mazda 323
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
