Question about Pioneer Car Audio & Video
I have installed my pioneer deh-1100mp and i have power but when connected it burns the fuse in the back of radio and suggestions thanks
merle840
  • 113 Answers
SOURCE: my pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Posted on Apr 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: can I install a pionerr DEH 1100mp cd player to my
Oh yes. Definately. You hook up red and yellow wires together on the positive side of battery. Black negative wire goes to negative on battery. That's all there is to it. Besides the speaker wire which you will have a diagram on the bottom of the cd player to tell you which wire is which
Posted on Jul 10, 2009
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
SOURCE: changing clock on pioneer deh-1100mp
turn the unit off.then push the power button and hold till clock flashes,then use your arrow keys
Posted on Dec 12, 2009
jimdoe
  • 4 Answers
SOURCE: Installed my Pioneer DEH-1100MP When
Does your car have a Factory amp if so u need to find the blue wire ( on most cars) and either ground it out or and power to it, it should turn the speakers on for you to play
Posted on Nov 30, 2010
I need the wiring/harness diagram for pioneer deh-1100mp
Order a new one. It is difficult at best to connect wires to the pins without getting a short. New ones are cheap and available from a bunch of places.
Aug 26, 2016 | Pioneer DEH-1100MP Car Audio Player, CD-RW...
I'm trying to install a pioneer DEH-64BT radio in
Check the ariel fuse with the power supply (+Ve) wire for open. If it found OK, measure the main voltage that come to that fuse carrier. You must have knoledge to use a multimeter. If fuse is found blown up, do understand that, there is some wiring mistake, caused a short circuit.
Chekc the wirings once again and replace the fuse only after that.
Feb 25, 2012 | Pioneer Car Audio & Video
Installed my Pioneer DEH-1100MP When radio is turned on display /tuner/aux comes up Can set stations etc but no sound With light tester to speaker wires there is power etc
Sep 10, 2010 | Pioneer DEH-1100 CD Player
No audio on Pioneer DEH-1100MP
I'm having the same problem worked for a couple of days then just stopped playing music
Jul 17, 2010 | Pioneer DEH-1100 CD Player
Hey, I am installing a pioneer 1100mp with adapters I purchased from walmart. I wired everything together and now when I hook it up the interior lights do not work and the radio has no power. what am I...
sounds like you may have a shorted wire . make sure you tape up all unused wires seperatly. so they dont short to each other. also helps if you could tell us what kind of car you have
Feb 13, 2010 | Pioneer DEH-1100 CD Player
Need to replace the original radio on a 1999 Ford Ranger XLT (F87F-19B132-AB) and cannot identify pin connections to install a pioneer DEH-1100MP. . Need the wiring diagram for the harness connection to...
buy a adapter from local car audio store if not look in a haynes book they should have one just sitting around local auto parts store take a pic of it if u dont want to buy or write it down
Oct 03, 2009 | Pioneer Car Audio & Video
Can I install a pionerr DEH 1100mp cd player to my boat? If so can you walk me through the process?
Jul 10, 2009 | Pioneer DEH-1100 CD Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Car Audio & Video Logo
61 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
