Question about Motorola Mobility RAZR V3
Phone won't recognise handsfree
For some reason, my Razr won't find my handsfree when I look for devices. I've tried it with a couple of handsfrees and it still won't work but it will find other peoples phones and my PC.
My handsfree is the motorola handsfree that was sold specifically for this phone and i've got it to work on other people's phones so it must be my phone? Any ideas?
    Brigadier General:
  • 7,752 Answers
Try doing a master reset and master clear that looking for it again....that should work and may sure that the handsfree bluetooth is active.,so the mobile can find it.
Posted on Jan 20, 2008
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
Motorola bluetooth hbm 210 won't pair with kyocera cricket phone
There should be a profile on your Kyocera phone for "Handsfree" note this is different from "Headset" Set it to Handsfree, and then try to pair the two devices.
Jul 20, 2011 | Computers & Internet
When i connect handsfree to phone i can listen to music but i cant connect to calls
If you cannot answer calls probably the answer to this problem that either your BlueTooth handsfree headset device is either malfuctioning or that when you registered the handsfree device you did not search for the service profiles and lock those in or either the handsfree headset device does not have an microphone.
Jun 27, 2011 | Cell Phones
Rejects my Samsung Galaxy
Try to reset all the settings you've done, on your phone and on the speaker.
If you've done this, you could try to do the whole part of connecting your devices again and it should work!
Mar 26, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • From the Menu screen, select Settings
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Dec 31, 2009 | Sony Ericsson K800i Cellular Phone
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
My simcard,not recognised
Try putting a piece of paper behind the simcard when you place it in your phone. I think the sim card is not attached properly. Place a paper so it will have a better contact on the phone.
May 16, 2009 | Motorola Mobility Earwrap Handsfree For...
Audio problem in head phines
YOUR PROBLEM IS NORMAL. PLS. CLEAN THE CONNECTION POINT BETWEEN YOUR EARPHONE AND YOUR PHONE. IT MUST BE RUSTED SO CLEAN IT PROPERLY WITH A POINTED PIN AND RETRY TO USE YOUR EARPHONE(HANDSFREE)
IF THE PROBLEM IS STILL EXISTS. THE WIRE OF YOUR HANDSFREE'S WIRE MUST BE DAMAGED BY USING IT UNPROPERLY. SO IN THIS SITUATION YOU NEED TO CHANGE YOUR HANDSFREE WITH A NEW ONE. THIS WILL SOLVE YOUR PROBLEM
REGARDS
KETAN PATEL
Feb 04, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Pair up to an handsfree device
first put the blutooth in pairing mode...what model of bluetooth is it i might be able to tell you hwo to do that if you dont knwo how. than turn cell phone on if not already.click the main menu button and then the settign folder. scroll down to connection and click itthen click "blutooth link"then go down to "add audio device" click yes to turn on bluetooth then if blutooth is correctly in pairing mode it will find it when it does click on it and piut in the pass word 00000000. and your done.
Mar 20, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Handsfree
make sure you have the profile set to headset. Goto your look through your phone settings.
Dec 08, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
188 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
