Keeprite mod#cgk075n07 - Heating & Cooling
Keeprite Mid Efficiency furnace. Why won't blower shut off?
The thermostat may be set for continuous blower operation.
Dec 17, 2015 | Heating & Cooling
My keeprite furnace not working getting 3 green flashes
Pressure switch open, when it should be closed.
Oct 24, 2015 | Heating & Cooling
Keeprite furnance showing 7 flashes blower fan on no fire inside furnance
Limit Or Rollout Switch Open--Requires Manual Reset.
Read Sticker On Unit--Codes Are There.
Mar 07, 2015 | Heating & Cooling
How do I change the furnace filter in a Keeprite CC18?
there should be an access where the cold air return goes into furnace.
just slide filter out
Feb 11, 2015 | Filter Heating & Cooling
Keeprite fornace is giving ten flashes .what is the problem
Short cycling is very comon when you have a dirty filter.
May 18, 2014 | Tools & Hardware - Others
Keeprite furnace
Is the furnace sitting directly on a concrete floor? If it is, it is taking up moisture from the floor. You need to get it up on blocks or some very solid base.
Oct 26, 2013 | Tools & Hardware - Others
2004 Keeprite High Efficiency Furnace won't heat.
Do you have the model number? There is a problem with either the blower motor sensor or the ignitor. When the furnace get a signal for heat, the blower motor comes on and then the ignitor. If either one of those fail then it stops, waits and tries again. When the tech was there, if he did not replace any parts then he did not do his job. You can call them back out because the issue was not resolved or you can post the model number for us.
Nov 04, 2017 | Heating & Cooling
Keeprite furnace manual
for a few days now my furnace "when it starts theirs a loud whining noise , i did check the noise is coming where the motor area is.. its stops when the blower comes on....but it getting louder! so is it one of the fans??
Oct 03, 2010 | Heating & Cooling
Keeprite furnace will come on heat up but the fan or blower doesn't blow but creat noise. please tell me how can I fix it. Regards Andre
Blower motor is either burnt or Ihave also seen the fan relay on the board burnt..test for 120v power out of the board at the blower leads if so replace motor, of no replace board
Feb 06, 2010 | Omega Keeprite Furnace Flue Exhaust Venter...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
