DVD and VCR doors will not open
Power is ok, red and green lights are lit. Remote or manual attepts with open/close buttons produce no results.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Disc loading mechanism fault. Contact any service technician to repair it. Have to take out the mechanism from the set for repair. It is somewhat a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 19, 2015
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Need a code to program a magnavox dvd/vcr for a universal remote control. the remove is a philips cl043. could you find the code for me please?
Hello
The setup codes to check with Magnavox DVD/VCR cobo to Philips CL series remote control are:
0247
[0093 0230] [0598 0230]
0456
[0914 0286] [0969 0286]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Code Search Method
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Sep 18, 2011 | Philips Universal PH301S Remote Control
Gflight@yahoo.comdo you have the universal remote code for emerson dvd vcr combo ewd2202
Hello
Unversal remote setup codes for Emerson DVD/VCR combo are:
0456 [0458 0227]
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK
Aug 13, 2011 | Emerson EWD2202 DVD Player/VCR
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
I need to program the SV2000 VCR/DVD combo to work with the WOW cable universal remote(ATLAS OCAO 5-Device Remote Control, M1056). Please give me the secret codes. :)
Hello
Check with these codes:
0456 [0458 0227]
Direct Code Entry
OK.
Jun 19, 2011 | Funai PY90VG DVD Player/VCR
Need a code for zenith/vcr combo.
Program a GE Universal Remote Using Code Search Make sure the device for which you want to program the remote is turned on, and that the GE universal remote has good working batteries in it. Batteries that are weak may keep the universal remote from being programmed. Press and hold the Setup or Code Search button. Again, the name of the button will vary between GE universal remote models. Once the indicator light is lit, you can stop pressing the button. Press the button with the name of the device for which you want to program the GE universal remote (such as TV or DVD) and release it immediately. The indicator light should flash a time or two and then simply stay lit. Now all you have to do is point the GE universal remote at the device you selected, press the Power button and release it. The catch is that if the device does not turn off, you must wait at least two seconds and try again. The GE universal remote will attempt to program the right code for the device, cycling through all of its built-in codes. This can take up to 250 attempts. When the universal remote (finally) catches the right code and is programmed, the device will power off. Once this happens, press the Enter or Save button on the GE remote to complete the programming process. and for free
Jun 02, 2011 | Televison & Video
I need the codes for a GE universal remote for a Daewoo TV
Welcome to FixYa!
You can try the following GE Universal Remote codes for Daewoo TV:
0130
0004
0009
0100
0005
0138
0043
0140
0039
0252
0279
0444
0080
0042
0058
0017
0010
0126
0018
0127
0019
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
If none of the codes listed work for your device try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER button (Should your remote model not have an ENTER button, then press the OK button.) The INDICATOR LIGHT will go off.
Thank you for using FixYa!
Have a great day.
Jas247
Apr 20, 2011 | Televison & Video
Need remote control code
Hello
Three digit universal remote control code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote control codes for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Four digit unversal remote control code for Panasonic TV/DVD/VCR combo is
0437
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Direct Code Entry
OK.
Dec 02, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Door opened and will not close or open now
Drive should have a feature to disconnect from door to allow for manual closing.
Jul 15, 2009 | liftmaster Chamberlain Garage Door Opener...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
