Question about Watches
How to remove these two pins? - Watches
  • Watches Master
  • 3,957 Answers
With an appropriate size drift pin (equal to or slightly smaller than the hole), tap them out from either side. Do not lose them.
Posted on Apr 19, 2015
How to remove links from Invicta 0132 wildflower
Normally on this type of Invicta you would use a slim punch to push out the little pins at each end of the link section you want to remove, then reattach the band using one of the removed pins.
In some cases one end of a pin will be slightly wider than the other so that the pin is meant to be removed in one particular direction. If you can't tell any difference, the pin will probably come out either way. You may use a small hammer to tap the pin back in if needed but don't scratch your band.
Feb 07, 2015 | Invicta Watches
How do I remove a link from the Stauer Colossus Hybrid Chronograph
Removing a link from the wrist band of the Stauer Colossus watch is a task that requires some mechanical talent. The links are held together with pins. These pins need to be pushed out. I strongly recommend the purchase of a "Watch Band Link Pin Remover" (got mine on eBay for $7). Prepared with this tool, the steps are as follows.
a) Separate the wrist band at the position where the strap and latch are held together. Careful! This pin is spring loaded.
b) The links that can be removed are marked with an arrow on the interior side. The pin should be removed in the direction indicated by the arrow.
c) With the previously mentioned tool you will be able to perform the hardest part, namely push out the pin by 3/16". In the image below note how the pushed out pin goes into the groove of the tool.
d) Use a small screwdriver or a punch with diameter of less than 0.07" (or 1.8 mm) in order to push out the pin completely (see second picture).
The push pin of the tool can be reversed which is helpful for re-assembly. I recommend smoothing the one end of the pin with a small file or sandpaper. This way the pin enters easily into the hole of the lower section. Else you run the danger of bending the link if the pin is not correctly positioned and you apply too much force.
Oct 24, 2012 | Watches
Removing links from a longines stainless bracelet. It's a L2.666.4.51.6 model and appears to have single screw pins but I cannot be for sure if they are actually screw pins or split push pins. Can...
here is a solution..
Each removable link on the watch bracelet has an arrow that indicates the direction of the pin to be pushed out .first decide how many will go out than find a tiny nail to be used as " pin pusher"
Simply align the pin that connects the links with the pin on the wood table and with a small hammer/plier hit it to push the pin out...there it comes..and after taking out linls ,connect the remaining link parts together and put the pin back into....
Some people prefers to use a pro type pin remover..it is a cheap tool..just in case pls visit the URL below..on this link there is an article as Watch Band Adjustment Tool Link Pin Remover too..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://reviewsalert.com/watch-repair-kit-16-pc-deluxe-tool-kit-repair-pin-remover/
Oct 07, 2011 | Watches
I need to remove metal links.
Thanks
Sep 11, 2011 | Lucien Piccard 26024 Wrist Watch
How do I remove a link from a casio watch bracelet?
Thanks
Sep 11, 2011 | Casio EF512D1AV Watch
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
I need instructions on removing links from a Fossil Stella watch
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
Oct 17, 2010 | Fossil FS2919 Wrist Watch
How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    Having trouble removing pin from men's Ebel 1911
    Watchmakers are using special pin removing tools and punches. You can find them on Ebay. If you have pins you can not damage threads as pins do not have any threads - they are friction fitted. Punch must be the size of the pin end you can see. Some pins come out easily, some quite hard, so, use appropriate strength to drive pins out. In case if there are screws - use small screwdriver to fit in the slotted screw end and unscrew the screw.
    Rate me, plz.
    Jan 06, 2010 | Ebel E Type 9157C11/5716 Wrist Watch
    Is there any way to adjust the band without a special tool?
    Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
    Make sure to examine the watch and which links have pins. Some watches are designed to have a row of removable links with pins.
    Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
    You may need to use something a little stout like a butterknife to tap the pins out from the links.
    The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
    Oct 04, 2009 | Festina 16177 3 Watch
    Watches Logo
    24 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
