Question about Makita 6916fd Impact Driver & Dc1414t Charger Case
Dc1414f charger does not work anymore how to get the charger back charging again
Charger does not show any lights anymore after having been left charging a battery overnight
  • Makita Master
  • 1,836 Answers
  • BEWARE ! In recent years, on marketing technical reasons loader print separately orderable significantly
    more expensive than a new complete charger with many brands.
  • Panasonic Festool Bosch Dewalt can have on a different base a Replacement powerprice , but sometimes most in the budget range its better to buy it complete new. its oft cheaper.
  • If On download page below the picture you see the word processing .... wait be pati?nt until there pop upped the word Get Manual underlined in stead of.
  • MAKITA DC1414F BATTERY CHARGER Service Manual free download schematics...
Posted on Oct 12, 2016
Sony E-reader PRS-T2 wo'n't charge
Use a mobilephone charger, not a cable for PC; then update the firmware.
Nov 13, 2013 | Sony Computers & Internet
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
Sep 06, 2012 | Plantronics Explorer 210 Wireless...
My sony ericsson xperia x10 started to freeze and tured itself off . tryed turning it back on it vibrated then did nothing . tryed charging it . at first the red light was coming up when i conected the...
Sounds to me like the device is faulty and there is nothing you can do about it. You will need to return it to the place you got it from. I deal with this sort of thing on a daily basis at work and that's what we usually do with phones with similar problems.
Mar 10, 2011 | Sony Ericsson XPERIA X1 Smartphone
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
I tried to charge my car battery with a Chicago Electric charger model 66783. I followed the directions for charging the battery in the vehicle. After selecting the charge rate of 10 AMPs, the ammeter...
Relax, the charger is working fine. What it is doing is charging the battery to 15.5V. During this time, the "charge complete" LED is off, and the current meter shows the needle going to the right. When 15.5 volts is reached, the current is shut off, the needle goes back to the left, and the LED goes on. When the battery voltage drops to 13 volts, the current goes on again, etc. At the beginning, with a very depleted battery, the needle will be towards the right, then as the battery gets charged close to full capacity, the needle will bounce back and forth because the charger is feeding current in short pulses. Towards the very end of charging, the needle will stay longer and longer at the left end (the LED will be ON), and spend less and less time to the right (LED will be ON for longer periods, and "blink" OFF less and less). Finally, at full charge, the LED will stay ON, the needle won't make excursions to the right, etc.
Dec 29, 2009 | Chevrolet Classic Cars & Trucks
Harmony 890 just went dead. Nothing. Nada. Not
I have an 890 also. I've found that the remote doesn't always charge when it the charger. I have to put a rubber band around it and make sure it shows that the the battery symbol on the display is showing that it charging. Or the battery isn't taking a charge anymore and I'd try to replace it. Doesn't really hold a charge very long either.
Oct 27, 2009 | Logitech Harmony 890 LCD Remote Control
My canon fs 100 doesn't turn on
I took the camera to the representative and we started various tests such as:
Tried My battery in OTHER camera .... not working
Tried OTHER battery in MY camera .... works
Tried charging MY battery in OTHER Camera .... works
Tried MY battery in MY camera and charged .... worked
Bottom end is that my charger is not working although it heats when "charging".
Now i will look at the pins in the charger to see if they are working or not.
Whatever the case .... getting a new charger.
May 29, 2009 | Canon FS100 Flash Media Camcorder
Jazz DV169 issue
umm i have jazz camera and i didnt have a charger **** i bout a motorola house cahrger and it charged my camera.
Aug 01, 2008 | Jazz DV169 Camcorder
Battery not charging
You need a new battery. That battery goes dead maybe its a factory defect its very rare this to happen but try to contact the Company to ask if you have a warranty for this unit. One more thing make sure that your charger is functioning.
Aug 04, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Makita 6916fd Impact Driver & Dc1414t Charger Case Logo
70 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
