Question about Whirlpool WFW95HEDW WFW95HEDW 4.5 cu. ft. Duet ENERGY STAR Qualified Steam Front Load Washer with Adaptive Wash Technology Precision Dispense 12-Hour FanFresh Option With Dynamic Venting Technology in White
Locked Front Door, Panel Unresponsive, Pump Humming
We ran the washer without turning on the water first. There were error codes, but they disappeared once I hit the start/stop button. The Door-Locked LED is blinking and the pump is humming. The panel is unresponsive and there are no error codes anymore. We've attempted to reset it by unplugging it. There is no lower panel to remove on this model, as all of the current answers here suggest. Help!
    Genius:
  • Whirlpool Master
  • 1,585 Answers
Sounds like ure pump is blocked
Posted on Apr 21, 2015
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
Amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Nov 05, 2011 | Amana Washing Machines
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
Won't run
yes at the bottom of washer remove panel shop vac water pump
Feb 01, 2010 | Samsung WF203ANW Front Load Washer
Model # GHW9100LW on final rinse and spin water remains in washer, door locked and humming sound comes from machine....pause/cancel will not unlock door or start new cycle... what might be the problem?
Sounds like the pump is trying to drain the water but something is clogged in it or the pump itself is bad. Door wont unlock if machine thinks there is water inside. Remove front lower panel. pump is in center. Unscrew cap and remove attached filter. Be prepared for water to come gushing out once filter is removed. Clean filter and reinstall. If problem persists then the pump itself needs to be replaced.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked code F21 wont run or cycle or empty water
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Jan 13, 2010 | Kenmore HE2 Plus Front Load Washer
Door won't unlock
remove bottom panel reach up to lock area pull down on small tab to release door if tub has water in it remove pump filter aacess by turning counterclockwise (have towels handy dip out as much water as possible first)
Sep 09, 2008 | Kenmore 46462 Front Load Washer
Whirlpool WFW95HEDW WFW95HEDW 4.5 cu. ft. Duet ENERGY STAR Qualified Steam Front Load Washer with Adaptive Wash Technology Precision Dispense 12-Hour FanFresh Option With Dynamic Venting Technology in White Logo
427 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
