Picture with retrace lines - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
You can get a detailed description about this fault by one among the post by this site.
Posted on Apr 19, 2015
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Blue Saturation with retrace lines visable
could be but there are a few checks that need to be donr first.. Try to turn down the g2 control just a bit on the flyback transformer. If no effect unsoder the blure drive transistor on the crt board If the blue is still there that means the crt is shorted and you could try to clean the elements with a crt rejuvenator and see if that helps. If the screen goes to red and green after you disconnect the blue drive transistor then you need to check the osd drivers as well as the rgb output drive from the video IC. If the blue gun in the tube shorted or leaky I have in the past and it really works a isolation transformer that plugs in to the crt socket and the other end plugs into the crt. What this does is isolate the the gun of the crt from the filiments and thats where they get shorted or leaky but for how long it will last who knows.
Posted on Mar 26, 2006
Arpi
  • 326 Answers
SOURCE: Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Posted on Jul 17, 2007
SOURCE: av32d305 yaa retrace line on the top of the picture
yes on the top of the picture
Posted on Nov 29, 2007
Picture up side down vertical retrace lines
Upside down picture is due to the connection reversal to vertical scan section winding at the deflection yoke.
If you wish to know more about retrace lines, and the repair work to it; visit this site. http://electronicshelponline.blogspot.com/
Reasons for retrace lines are given with illustrations.
Mar 30, 2015 | Televison & Video
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
What can be done with retrace lines on my set
Reasons and repair procedure to retrace lines in picture with CTVs are given with illustrations.
Aug 13, 2014 | Samsung TXD1972 19" TV
No picture retrace lines
Video output [Matix section] has damaged. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 22, 2014 | Televison & Video
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Retrace lines and poor convergence
you have bad solder connections on the convergance board solder then and get back to me k
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
Jul 17, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
