Will not pump water. Everything seems to be hooked up properly.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for blockage,s
Posted on Apr 21, 2015
On my 2002 sr5 sequoia radiator doesn't seem to be building up pressure,but,everything seems to be working properly ??? any comments??
leak in the coolant system
possible causes
cracked plastic radiator tanks ,
cracked hoses
rusted welsh plugs
corroded housing behind water pump putting water into sump ( grey sump oil)
have it pressure tested to find the fault
Jan 08, 2017 | 2002 Toyota Sequoia
Dishwasher will not pump water.
probly some thing stuck in pump
Apr 19, 2015 | Washing Machines
Our dishwasher is not pumping water.
could be blocked some were or its the pump
Apr 19, 2015 | Computers & Internet
Drain pump isn't working properly or mystery clog
I would replace the drain pump if you are sure there are no obstructions to the water flow.
May 19, 2017 | Washing Machines
Will the the pump run if it is connected
You can not connect the pump to run 'backwards' since the motor rotation is an internal connection you cannot change. Yes, the port should have water pressure, not a vacuum. Perhaps the wall inlet adapter is installed into the wrong wall port? Did someone change the wall port to allow for a suction side cleaner? Is this a new installation or sudden problem with an old one?
May 15, 2010 | Polaris Pb4 - 60 Booster Pump
HOW DO I CHANGE MY WATER PUMP ON MY 99 GMC YUKON?
remove belt drain radiator remove fan shroud remove fan /pulley remove top hose on water pump and lower hose un bolt water pump remember mark bolts because lower longer need sealant due to they go into water jacket remove and clean around both water openings before setting in place hook up upper bypass hose easier to hook up before install--replace and rebolt everything
Oct 10, 2009 | 1999 GMC Yukon
No water loaded
Have you checked the water input is not blocked or kinked?
May 11, 2009 | Miele Premier-Plus Built-in Dishwasher
Heater gets cold while running down the road
the thermostat is stuck open. Youv'e got a little rust in the coolant, right?
Nov 25, 2008 | 1995 Chevrolet Caprice Classic
Home water well problem
Two things maybe. Are you sure the air is coming out? Not in? If its after the pump stops and then stops after a while it may water rising back up into the sleeve after the pump stops. If you can hear it while the pump is running then maybe its the opposite. Hold a flame near the sound tho see which way the air is going.
Feb 27, 2008 | Washing Machines
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
