Our dishwasher is not pumping water.
Everything is all hooked up properly. Please help Thank you
    Top Expert:
  • Computers & ... Master
  • 8,246 Answers
Could be blocked some were or its the pump
Posted on Apr 19, 2015
Dishwasher will not pump water.
probly some thing stuck in pump
Apr 19, 2015 | Washing Machines
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Kenmore diswaher----all cycles seem to work well...problem when cycle is over water remains...if the buttom for canel/drain is then pushed , all the water will drain with no problem...Any...
Hello, Thank You for using FixYa. I will be helping you today. This sounds like a slow drain.I would check the drain where the drain line hooks up.If that checks ok the most likely culprit would be the drain pump not the timer.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Dishwashers
WE JUST BOUGHT A NEW DISHWASHER DU1345XTVB HOOKED EVERYTHING UP CORRECTLY AND RAN A QUICK CYCLE THRU IT AND WHEN IT WAS DONE THERE WAS STILL WATER IN THE BOTTOM. THIS WAS TO REPLACE THE OLD DISHWASHER SO...
Make sure the garbage disposal is working, if it is not then it will not allow
the dishwasher to drain. Also make sure there is not blockage in the intake port on
the disposal where the hose connects itself. If you installed a new disposal, there
is a knockout that must be struck out inside the connection port.
If you have an "air gap" installed (next to the faucet which looks like
a small cup upside down, it may be gunked up, remove and clean, or replace it)
If the hose came inside the dishwasher did you install it on the proper port on the
dishwasher pump, many have two and one is blocked off. (it is unlikely but depending
on the amount of water and the type of subflooring under the machine, it could have
pumped out unnoticed and drained through a wiring hole).
Hope this is helpful
Mar 26, 2011 | Whirlpool Dishwashers
Dishwasher- dishes not clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Thermador DWHD64 Dishwasher
Water level/dirty dishes and traps
sounds like the drain pump is not doing its job to recycle the water and allow for replemish of fresh water for the rest of the cycles,try looking closely at pump out system and monitior how fast it disposes of water hope this helps
May 27, 2009 | Kenmore 15121 Built-in Dishwasher
Water is not pumping into dishwasher
When you connected the water line did you remember to turn the water valve on?
Feb 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 2200 Series Dishwasher pumping through air gap
you have a clog some where bewteen the airgap and the sink.. . take everything apart and clean it thoroughly. let me know that this fixes the issue
Feb 13, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
