Question about Wanderlust Interactive Pink Panther Hokus Pokus for Windows
Does anyone have the Disc Key for an old game: Pink Panther, Hokus Pokus Pink? I have the cd-rom, but not the disc key, so I can't install it.
If I try to install it on my new laptop, it does give that option, but when I click on it, it wont because the game doesnt work on windows 7. When I try to install it on my old laptop with windows xp, the install button doesnt appear and it asks for a disc key, which I dont have.
I have Brian Lara International Cricket 2007 Original CD - PC DVD-Rom I have installed it.. but it is asking: Enter a disc key for the disc labelled ICC2007. Usually the key can be .. what next?
We at Fixda doesn't have keys for pirated computer games and personally, I don't have time to lose for looking ups cracks for you.
Buy your computer games from a legitimate provider or download another pirated version on your own risk and hope the best it should not have some nasty malware incorporated and should have some activation key incorporated.
Also you can join to some Gamers Forum where you can share information on games with other members
Aug 09, 2015 | Video Game Consoles & Games
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
Cannot boot from cd rom on compaq evo d310v, i have lost all disks but have the product key if it makes a difference. So what i wanted to do was wipe the hard drive with dariks boot and nook then inst
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Apr 21, 2013 | Compaq Evo D310v PC Desktop
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
I have a HP G60-519wm, pn vm083ua. It gave me an error of no bootable drive and hard disc failure. I replaced hard drive, purchased new recovery discs from HP, and downloaded a boot disc. It still gives me...
try to open the cmos setting by pressing the f10 key then check if the hard drive you installed has been detected, if you can see it, go to boot option then change the 1st boot device to cd-rom drive then the 2nd boot device will be your hard drive then click esc to save the setting put your recovery disk on the cd-rom drive then reboot the unit if ask press any to boot from cd rom just press a key or simple tap any key on the keyboard, then follow instruction.
Aug 03, 2011 | Computers & Internet
Frozen throne was unable to find war3.exe. please make sure your game is correctly installed and that your frozen throne disc is in your cd-rom drive,and try again. that was the error,everytime a attemp...
frozen throne was unable to find war3.exe. please make sure your game is correctly installed and that your frozen throne disc is in your cd-rom drive,and try again
Jun 12, 2011 | Video Game Consoles & Games
Trying to run my old HPP game in windows 7 but can't get compatability
There is a good chance that you won't be able to run that game on windows 7 with any sort of compatability mode. There is however another more advanced method that can be used to run very old games. You can set up a virtual machine on your windows 7 operating computer, and on this virtual machine install an earlier copy of windows, windows 98 for instance, which will run the game just fine.
To do this you need a copy of windows 98, thats the easy bit.
Then you need to download and install Windows Virtual PC and check your software compatibility. The download link can be found here.
Once you have Windows Virtual PC installed then you will need to set up your first virtual machine.
  • Start up the program
  • A wizard will pop up and help you through the creation of your first VM
  • Select "Create Virtual Machine" and then click Next
  • Select the Name For Your VM then click Next
  • Then from the drop down menu to the left select Windows 98 and click Next
  • Select "Using The Recommended Ram" then click Next
  • Select "A New Virtual Hard Disc" then click Next
  • My Suggestion is to leave these at Default, then click Next
  • Check over the details and click Finish.
That should see your first VM Setup. Now go to the Virtual PC Console, select the VM you just created and click start. You should see a window that pops up showing what appears to be a PC starting up. That is the virtual PC starting up just like your pc would. Starting up for the first time can take quite a while so be patient.
The VM should then display the message "Reboot and Select proper Boot Device or Insert Boot Media in selected Boot device".
It's at this point you need your copy of Windows 98, on you VM window you will see on the menu bar at the top of the window the drop down "CD" click on this and select your disc method, which CD drive the disc is in or if it's an ISO file select that option.
Once you have that selected then:
  • Press the space bar and the screen should change
  • Select boot from CD-ROM, press enter
  • Select Start Windows 98 Seyup from CD-Rom, press enter
  • Press Enter when promted to
  • Select Configure unallocated disc space, press enter
  • Select, "Yes, Enable large Hard Disc Support". press enter
  • Press Enter when promted, the VM will now restart
  • Repeat the first 3 steps
  • Setup should now be formatting your virtual hard drive
  • Press Enter when prompted
  • The Windows setup Wizard should now be running
  • Follow the wizard through and Windows will start installing
  • During this process the VM wil restart several times
  • Once the VM restarts and again promts to start from CD-Rom or Hard Drive, select Hard Drive, then press enter.
  • Once your VM starts up in Windows 98, proceed with the installation of the game and any other software it needs.
Once you've done all this you will have the perfect compatibilty platform set up for any old games you own, as it is Windows 98 not some mode stuck on the side of you version of windows.
This is quite a long and complicated method, but it will work and it will allow you to play just about any pre 2000 game going.
May 03, 2011 | Wanderlust Interactive Pink Panther Hokus...
Disc key for popT2T_PLAY
The Install Key for Prince of Persia: The Two Thrones is:
BZ7A9-X488N-725MY-E9FND-TLPDZ
Please note, this key code is only used for the installation of the game.
Feb 10, 2010 | Ubi Soft Entertainment Prince of Persia:...
When it comes to installing the operating system accepts perform partition, also formatted, but when this by installing the operating system files and goes by 25 % crashes and a blue screen with different...
I would lay money on the disc being damaged ! if you have access to another computer with a cd burner in it try to make a copy of your operating disc and then try to install it again. Sometimes when the disc is scratched and you make a copy of it due to the oversampling, it will correct the bad spot. The product key code will of course be the same as on the old disc. I would not make copies to share with others as this is of course illegal but to back up your own operations disc this is permissible. You may also try to clean your cd rom with a good quality disc cleaner as this may also help.
Dec 20, 2009 | Toshiba Satellite A70-S249 Notebook
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
Wanderlust Interactive Pink Panther Hokus Pokus for Windows Logo
55 people viewed this question
Top Wanderlust Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Wanderlust Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
