Question about Refrigerators
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
  • Chet
    Chet Apr 19, 2015
    It's a FFFL 1800 hotpoint fridge freezer
  • salem
    salem Jun 08, 2015
    no it is a Korean fridge called (kiasse)
    New Friend:
Both fans, freezer and fridge are working but no cold air inter the fridge side
Posted on Jun 08, 2015
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Refrigerators Expert
  • 310 Answers
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Posted on Apr 25, 2015
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
Curcuit daigram
Please check on the link below for a good visual description of the fridge parts:
click this link:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/278/identifying-fridge-freezer-parts.html
For a visual description., click on:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/1435/how-a-fridge-works.html
Aug 17, 2011 | Refrigerators
Whirlpool 445L white Fridge Model: WRID41TW It started with dripping water into the fridge from top (freezer?). I was unable to locate the water source. Three days later, the freezer started frosting...
Have you tried it after letting it defrost for a couple of days . It sounds like it was just frozen up. If the freezer is still working then it is the defrost drain is frozen up.
Oct 14, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Feb 03, 2009 | Refrigerators
I have an LG fridge top / freezer bottom which I purchased exactly 3 years ago. The fridge has stopped cooling, although the inside light stays on. Also, the freezer is still working perfectly. Firstly,...
Most LG fridges have a 1 year warranty with some components exteneded, such as the compressor or sealed system repair. Those are usually 5 years or long, depending on the model.
Can you tell me the temp. in your fridge please? I have a strong suspicion that it may just be the thermostat.
Freezer and fridge don't cool at all. everything else works fine
Heya,
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Jan 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
