Question about Gates 1995-97 Dodge Intrepid Timing Belt Kit with Water Pump for V6 3.5L wit
97 intrepid 3.5 sedan starts & dies
What will cause my 97 intrepid to start & die it runs for a few seconds each time the running time is consistent does not fluctuate I have checked all fuses relays replaced super clogged fuel filter the first thing I did was change the computer several times it would run & drive then die after a few miles then start & drive thought it was the ecm so I started with two rebuilt flashed esms not sure about the person that flashed them returned them wouldn't start at all I put a used one in it did the same thing as the original start & run for a few miles then die put another used one now it starts & runs for a few seconds did the key dance after the computer dance a little late I know just the disconnected batt code & the finished code am I getting bad advise or bad computers ?
Adidas SpringBlade running shoe tread splitting
there is not much hope for a solution to this problem as it is common to all shoes sold
Why adidas will not help is that they and all shoe manufacturers are aware that all shoes have a shelf life and if the shoe is not used in a short period of time after manufacturer the material used starts to break down and become unstable
it is the movement of the sole that sets the material and produces a long wear period but shoes ( and boots ) bought and stored will fail quickly with sole problems ( cracking, falling off , bits falling out etc )
Best advice is wear all your shoes on a regular basis for the first few months before leaving them in the cupboard and to get a retailer that will offer a replacement pair if the soles fail in a short period of time as a good will gesture for the customer
of course you can always resort to legal action as there is an expectation by the purchaser that the goods will last for a reasonable period of time regardless of expressed warranty period or not
Jul 31, 2016 | Adidas Mens Springblade Running Shoe
I am running an 100 metres in 2 weeks time...how do i train????
https://m.youtube.com/watch?v=0N3JQs0hpm8&autoplay=1 I hope this helps. I am not a doctor. YouTube will help.
Jun 30, 2016 | Running
I replaced the timing belt on a 2003 Hyundai Accent 1.6 engine. I'm having problems starting the engine. What are the steps to putting it back on time?
If by timing you mean that you aren't sure that you have the belt on the cam/crank assemblies properly, now is a bad time to mention it. This is an interference engine. Proper alignment of the crank/cam with the timing belt is critical and must be exact or serious internal engine damage will result. Even turning the engine too far without the belt properly aligned can damage pistons and valves. At this point if you didn't get it right, the damage is probably already done. For a quick check, disable the fuel pump, pull the spark plugs and perform a compression check. If it doesn't pass, take it all apart and assess the damage and repair as necessary.
Nov 25, 2015 | TBK Timing Belt Kit Hyundai Accent 1 6l...
What do you think about the roadmap strategy regarding Run 3 game?
The roadmaps gradually be a little more difficult. Within infinite mode the actual alien runs forever until an inability. In every session you generate points which later on could be exchanged for some other tools. There are several pyramids hovering within the space generally in run 3 full game. All those pyramids your own points, which means you should attempt to obtain them no matter what is the cost.
Nov 06, 2014 | Quiksilver Mens Pre-Game Running Full Zip
Service manual schematics
If you open up the unit, you may be able to fix the jack if it has come loose and maybe got a broken connection in the process. It may just be a "cold solder joint" causing the problem
Sep 04, 2014 | DIGITECH RP500 Guitar Multi-Effects Pedal
Were can i locate the timing marks on 1997 toyota Rav4
You will have to look at the camshaft gear and crank shaft gear there will be mark in side the timing case where the mark have to align up with the mark on the gears
Jun 01, 2014 | Gates 1999 TCKWP199BH Toyota Rav4 Timing...
84 pontiac T1000 timing belt replacement
Go to autozone dot com and make a free account, put in the vehilce info and look for the free guides, if they are not online, go to a store and see if they have CHILTONS or HAYNES manuals on it.
Oct 01, 2013 | Victor 1984 Pontiac T1000 Engine Timing...
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
Jan 14, 2013 | Running
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
Jan 13, 2013 | Running
Gates 1995-97 Dodge Intrepid Timing Belt Kit with Water Pump for V6 3.5L wit Logo
52 people viewed this question
Top Gates Running Experts
Are you a Gates Running Expert? Answer questions, earn points and help others
