Question about Janome Sewing Machines
HOW DO i REPLACE THE BULB IN MY JANOME J3 18?
I CANNOT GET THE COVER OFF TO REPLACE THE BULB.
  • Janome Master
  • 1,860 Answers
Sometimes there are hidden screws,, look for a plastic circle that you can lift gently with a small screw driver
Posted on Jun 03, 2015
Can I replace an ordinary light bulb in my Janome machines with a LED bulb?
as far as bulbs they will work fine IF you ever find the proper ones, size wise .
May 05, 2015 | Janome Sewing Machines
How do I replace the lightbulb on a Jamome 9000MC? Where is the lightbulb?
I'm pretty sure you just swing open the lamp cover and the bulb will be right there. It just pulls out.
This is a halogen bulb and will be spendy (over $20).
Feb 26, 2015 | Janome Memory Craft 9000 Computerized...
Where is the bulb located on the MC 9000
You can find it inside the side cover (left hand side).
Dec 14, 2013 | Janome Memory Craft 9000 Computerized...
Janome 7025 have mislaid manual and can't open side of machine to replace bulb, have removed screws but it won't come off.
After removing 1 or 2 screws on the side cover, that side cover should come off with a good tug. Janome also puts tabs on the side cover to help hold it on, and they do stick sometimes. If you can get your whole hand over the entire cover, get a good grip on it, and just give it firm yank.
Apr 27, 2011 | Janome Sewing Machines
Can you please tell me how to change the bulb for a Janome sewist 525s thank you
You have to take off the cap to the screw on the side of the cover. It is just bellow the foot tension. and then unscrew the side. It will then come right off, you may have to tug a little. Then, you can take the bulb out and replace it.
Feb 19, 2011 | Janome Sewist 525S Mechanical Sewing...
How do i open the side door on my janome 1018s where the neddles and light is
On some sewing machine the door is called Lamp Cover Door & has a hinge at the back of the door,, gently pull toward the back of the machine to open the door & the light bulb should be easy to get to.
Some are called Face Plate-there should be a plug in the middle of the door-remove gently with a small screw driver- there should be a small screw to remove-the door should come off easily--change bulb--replace screw-replace plug
Oct 07, 2010 | Janome Memory Craft 10000
How do i change the lightbulb on my Janome 6019 sewing machine?
On most sewing machines the light bulb is located inside the faceplate on the left hand side of your machine.
http://www.janome.com/documents/File/ManualFile/6019QC.pdf
The faceplate is part number 17 in this manual.
One that has been removed, the bulb should be visible. You will need to look at the old bulb to see if it a screw type or a bayonet type, in order to replace it with a new one.
If this is not correct try the Janome website for advice, they have a forum and an ask Jan section for problems etc.
http://www.janome.com/index.cfm/LearningCenter/AskJan
http://www.janome.com/fusetalk/forum/
I hope this is helpful to you!
Sep 17, 2010 | Janome 6019QC Mechanical Sewing Machine
I have a Janome 5700, the light has burnt out and there is no directions in manual for changing it, I also cannot find the burnt out light. Can you help. Thanks Penny
Most sewing machine lamps are located inside the face cover on the left hand side of your machine. It should pull open as it is hinged at the back and clicks into place when you close it. The lamp will be visible to you when you open your machine. It will either need a bayonet or screw type bulb replacement. You will need to look at the broken bulb in order to see what type your machine needs.
http://www.janome.com/documents/File/ManualFile/MC5200.pdf
If you look at page 4 of this manual, which is similar to your machine, you will see the face cover is part number 11. In the smaller picture below you can make out the hinge on the back of the machine that allows you to open the face cover like a door. Hope this helps!
Sep 03, 2010 | Janome Memory Craft 5700
How do I replace the light bulb on the Janome MC9000?
I HAVE A SEWING MACHINE CRAFT6000 BUT THE LIGHT IS NOT WORKING BOUGHT NEW BULB STILL NOT WORKING HELP PLEASE!!!!
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
96 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
