To change the bulb in the Pfaff Tiptronic 2030, you need the bulb remover that was in the original accessory package. Push the bulb remover up into the sewing machine (at the bulb) as far as it will go. Rotate the tool (and the bulb) one-half rotation counter-clockwise. Bring the tool and the bulb down and remove the bulb from the remover tool. To put the new bulb back in, put it into the diagonal holder until the pins engage. Push the bulb up into the lamp holder of sewing machine as far as it will go. Rotate the bulb one-half rotation clockwise. Remove the bulb changer tool. The bulb should remain in the sewing machine. This, https://www.sewingpartsonline.com/bulb-remover-412570101.aspx , may be the correct replacement for the tool.
To replace the light bulb on your Singer sewing machine model 9618, please follow these steps:
Turn off the sewing machine and unplug it from the power source.
Locate the light bulb cover on the left side of the sewing machine, just above the needle.
Use a small flat-head screwdriver to gently pry the cover off.
Remove the old bulb by gently pulling it out of the socket.
Insert the new bulb into the socket, making sure it is securely in place.
Replace the cover by aligning it with the slot and gently pressing it back into place.
Note: Make sure to use a light bulb that is compatible with your sewing machine's voltage and wattage specifications. You can find this information in your sewing machine's manual or on the light bulb itself.
You need to replace the lightbulb. You may need to remove the cover over the lightbulb off in order to remove the bulb. Take the bulb to the local sewing machine repair shop or order a replacement online.
FWIW, you may want to consider an LED bulb. They are much brighter and do not get hot like the standard bulbs.
some machines it's called the lamp cover door --these machine have a hinge at the back, carefully pull the door toward the back of the machine & it should open to show the bulb
some machines call it the face plate--there is a hidden screw under a plastic plug, gently pry the plug with a screw driver & then take the screw out, & remove the plate & the bulb should be easy to replace,just put the plate back on after changing the bulb & replace the screw & plug
happy sewing
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
