Question about Tablets & eReaders
My ipad will not switch on and no charging battery shows when connected to charger
  • 1,631 Answers
Try another charger...
it could have died.
if same result... Take iPad for repairs
Posted on Apr 19, 2015
4 Suggested Answers
  • 846 Answers
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Apr 26, 2010
charles0285
  • 160 Answers
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Please Rate
Posted on Nov 02, 2012
  • 1745 Answers
SOURCE: Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Posted on Feb 09, 2015
I would like to get help with this IPAD that the battery will not charge I just got this IPAD today from the seller.
First you have to verify if the charger is working. You can't charge an iPad on an iPhone charger, not a lot of people know that. Do you see the charge symbol? The charger may be weak, check it by trying to charge the iPad on another charger perhaps belonging to a friend. If that checks out, the battery has failed. Apple charges about $130 plus tax, places in the mall charge $90. If it is a used one, they fail after about 3 or 4 years. If it is new, contact the seller. Their reviews are good
https://9to5toys.com/2016/05/31/apple-128gb-ipad-pro-wi-fi-cellular/
Guarantee Cellular eBay Stores
Mar 22, 2017 | Apple iPad Tablets & eReaders
IPad will not charge even though battery and charge port both replaced.
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
Nov 30, 2015 | Apple iPad 64 GB 3G Tablet PC
My ipad is charging only when i connect to the external power.
Do you mean that once it's charged and off the charger, the iPad won't turn on? Your battery is no good.
Dec 12, 2014 | Tablets & eReaders
Why My wont charge my iPad charge
many videos onit just google it. good luck.
Aug 27, 2014 | Apple iPad Tablets & eReaders
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
My Apple iPad 4th Generation will not charge when plugged in. What should I do?
My ipad has done this twice. Both times it has been due to the battery going totally dead and a bad charger cord. Take it to a radio shack or to someone and have them to use one of there chargers wait a few mins. See if it begins to show any signs of taking a charge at all. It may take 20 mins. or so. If it doesnt then you will more than likely have to replace the battery inside the ipad. There have been some ipad batteries that havent lasted very long. Good luck and I hope this helps you.
Jul 20, 2014 | Apple iPad 4th generation
Ipad will not start?!
There are a few things to try. 1) Press the power button and the home button (on the front) at the same time. If that doesn't work 2) try plugging it into a different charger than you normally use. If that works, you need a new charger. If it doesn't show that it's charging within 30 seconds, your iPad charging port or battery probably has a problem and will need repaired.
Jun 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
I plug it in but it will not charge
You must use the Apple charger or allow extra time if using a non-Apple device. The standard output for a USB charger is 5 volts but Apple uses 5.17 volts. The battery icon at the top of the screen should show a bolt symbol when connected for charging. If it does not you may have a bad cable.
Dec 01, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Ipad won't turn on
Hold the on switch and menu button together for a hard reset. If you can reset it, there may be an issue with your motherboard. If apple doesn't replace it for you, You can get the board at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Feb 11, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
