Question about Electric Garden
Qualcast cylinder electric lawn E35 mower. Method of removal large drive pulley. is it threaded?
  • 81 Answers
SOURCE: Lawn Mower belt came off of pulleys
www.stollerlawnandgarden.com/
Go to this website, click on parts lookup in left hand column. Choose MTD then enter 13AN model number. Click on deck and it will show you how to route the belt. Hope this helps.
Posted on Jun 24, 2009
  • 16 Answers
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Posted on Aug 31, 2009
mowerman1857
  • 389 Answers
SOURCE: lawn mower not quite starting
Sounds like you have dirt and/or moisture in the carburetor float bowl. Remove the bowl and clean it out. place a small pan or bowl under it when you start to remove it to catch the fuel and look for water. It will look like a "bubble" floating at the bottom of the fuel. Get a can of areosol carburetor cleaner with a long tube on it, stick the tube up in the hole where the bowl nut goes and spray it out to remove and fine dirt that may be in there. The following is in CAPS because I cannot stress enough, the safety and hazards of using the carb cleaner:
USE SAFETY GLASSES/GOGGLES AND BE VERY CAREFUL USING THE SPRAY - - IT WILL BURN YOUR EYES AND IF YOU HAVE SENSITIVE SKIN IT WILL BURN THAT TOO
Posted on Sep 15, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Self-propelled lawn mower wheel removal
no ht they should both be the same try some wd40 and let her soak awhile. jd from la
Posted on Sep 19, 2009
Testimonial: "Ok, I'll keep trying. Thanks for the comeback. HT"
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
Qualcast rm34 assembly
I'm not familiar with the Qualcast rm34 assembly, BUT... from the "smoke" from beneath, I suspect that something has jammed/locked the blades, or blade pulleys, and the resulting slippage of the belt is causing the smoke.
With engine off, AND the spark plug wire FAR REMOVED from the spark plug, CLEAN OUT ALL DEBRIS FROM beneath the deck, above deck, AND from all areas in contact with the belt!
May 04, 2014 | Garden
Qualcast electric xr35 reel mower and I need a new rubber drive belt for it
It's as easy as Google-ing "Qualcast spares", the choice of suppliers is amazing. Most give next day or 3-5 day delivery.
Aug 31, 2013 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Qualcast Motor Mower Starts but will not run
there will be a butter fly in the carb that pulsates this is conected to rev cable plastic may have snapped or cable come loose
take it it is petrol
Jul 29, 2012 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Aug 30, 2009 | Garden
To remove clutch and drive pulley lx297 from the engine
there is a center bolt holding it on remove it put some penetrating oil one the crank let it soak it should slide off if not tap lightly with hammer while pulling down when you reinstall use anti seize and blue locktight on the bolt threads
Aug 18, 2009 | Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
37 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
Mike
Are you an Electric Garden Expert? Answer questions, earn points and help others
