Question about Cub Cadet Garden
How do I replace the left front axle on a cub cadet lt 1050 lawn tractor?
  • Cub Cadet Master
  • 1,169 Answers
Depending on how old you either remove the retaining nut or the push on cap to get the spindle out of the axle. Note if it is the push on cap you will need a new when replacing the spindle. The rest should fairly straight forward.
Posted on Apr 19, 2015
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
Sep 02, 2014 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
How do i replace the cooling fan on a cub cadet transmission 1050
you dont have to not unless it is broke then you have to remove the drive shaft
Jun 14, 2014 | Cub Cadet Street Sign- tractor lawn riding...
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
I am working on cub cadet lawn tractor lt 1050. how do i remove and replace the rear axel?
Hello.
SOLUTION ON How to Remove Lawn Tractor Wheels.
Owning a lawn tractor to take care of the grass and yardwork is convenient until the tires need repairing. It is inevitable that sooneror later the tires will go flat and need replacing. You can replace the tiresonce you know how to remove the wheels on your lawn tractor. Unlike automotivewheels which have several lug nuts, the lawn tractor tire requires only theremoval of a retaining ring to release the wheel from the axle.Front Wheels
  • 1 Park the lawn tractor on a level surface. It is better to park the lawn tractor on the driveway or solid shop floor rather than the lawn. Place a floor jack under the front frame and jack the mower up until the front tires are six inches off of the ground.
  • 2 Place jack stands under the frame on each side of the jack and lower the jack until the frame is sitting on the jack stands. If the mower is on the lawn, place a piece of plywood under the jack stands to avoid sinking the jack stands into the lawn.
  • 3 Pop the axle cover off of the center of the wheel. You can pry the cover off with a small flathead screwdriver or grab the cover with a pair of pliers and twist the cover off of the axle.
  • 4 Pull the retaining ring from the axle with a pair of needle nose pliers. Grab the ring from the closed side and pull the ring straight from the side of the axle. If necessary, use a flathead screwdriver to aid in spreading the open part of the ring so the ring will slide off of the axle.
  • 5 Slide the two washers off of the axle and then pull the wheel off of the axle.
Toolsneeded to solve the problem below. Floor jack,Pair of jack stands ,Small flathead screwdriver ,Needle nosepliers ,Vice grips
THEN SOLUTION ON How to REPLACE Lawn Tractor Wheels.
Thanks
Sep 15, 2011 | Garden
Steering locks when turned ti extreme left or right
If your steering lock when turning extreme is because the ETO busher on the front axle is wear out. Try replacing it. It is on the end of the axle.
Thanks.
Jul 18, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet 1050 changed oil now its wants me to change oil again and it smokes really bad now to much oil or too little
the 1050 holds 57.5 oz slightly less than 2 qts 64 oz. the filler stick is marked. shiould be over the add mark not over the full mark
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
138 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
