Question about Cameras
File error appears on screen when viewing pkotos
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Can have different causes. To many pictures on the memory card card is full. From the last picture file name ends with 999 or 9999.
Or there was an error while writing a picture to the memory card, caused by a power failure.
I would put the card in an external memory card reader and try to put all pictures in a folder on the computer. Then format the card FAT 32 or FAT 16 and then put it back in the camera. When switched on, first format the card again, in the camera, to make sure the camera can work with the card and the format.
Success.
Posted on Apr 19, 2015
The display screen shows " file error " only.
The manual can be viewed here:
http://www.fixya.com/support/p228383-toshiba_pdr_m4_digital_camera/manual-5928
I don't see anything about a file error message, though....
Have you tried using a different memory card, or formatting the one you have?
Jul 01, 2011 | Toshiba PDR-M4 Digital Camera
BSOD error. Bug Check String : IRQL_NOT_LESS_OR_EQUAL file ntkrnlpa. Please Help
if u are able to logon to the windows means next time post the brief error code also use free tool blue screen view to view the dump files and post me i will solve you
Mar 02, 2011 | Computers & Internet
My camera view finder shows"Check
Good day,
The CHECK DIAG appears in the view finder when the camera's automatic self diagnostic function detects an abnormality.
From here you must first perform error checking on your camera by doing the following:
Press the menu dial.
This will perform the error check on the Digital Signal Processing(DSP) and the Memory Circuits.
When no error is detected OK will appear.
If an error is detected it will be displayed next to DSP or Memory on the screen. Diag Error will also appear.
If Diag Error appears contact your Sony dealer!
What this means is that the camera is doing a routine check or has detected an abnormality with the system.
I hope it is just performing a routine check and there is nothing wrong with your camera!
Best of luck and let me know if this was useful!
Kind regards
Dec 01, 2010 | Sony DSR-500 Mini DV Digital Camcorder
File error Sony Cybershot DSC-W120
The LCD screen may display a FILE ERROR message when trying to view a still image on the Camera if the image was rotated, modified and overwritten using editing software on a Computer.
To play images you have taken on the Camera, it is recommended that you do not make any changes to the original image files.
It seems that the images are rotated or modified in the Computer.
Check the link give below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C387963
Aug 31, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
Configuration error code purple
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Oct 02, 2008 | Computers & Internet
File error when viewing pics
Your pictures appear to have been corrupted.
Here is what you can try:
copy the files from your card directly to the computer HD. Then look at the files with your computer system browser, and choose the full view, or in Windows it would be VIEW/ List or details . If the names are missing any letters, then simply do this:
Make a copy of the original file and rename it to something like:
I_G123B,jg (original renamed file...note that I added the B so the name is not the same as the original) to IMG123.jpg . Once the file is renamed to what may have been originally, you will be able to view the picture again.
Some times the corrupted name may be even more confusing. The main thing to remember is to make sure you have a .jpg or .JPG at the end so that the computer system will recognize the file format and be able to read the file. The way you name what is before the period ( .jpg) is not that important, but should reflect the original file for your own information.
This file corruption is more common than one may think. I have seen it on Nikons, Sonys, Canons.
And others.
Jul 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
File Error
File error means it cant read the file or the file is corrupt, i would try a new memory card or format the one you have.
Feb 07, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Missing "imagehlp.dll" error on installation
Uninstalling other makers software may remove a system file which prevents installation of Coolpix drivers from the Nikon View v5.1 CD on Windows 98SE systems. It has been reported that, when connecting a Coolpix camera to a Windows 98SE machine, the hardware wizard will not recognize the appropriate driver; this setup fails because the file "IMAGEHLP.DLL" is missing from the system. Installation will stop with an error message which mentions this file. This problem may be caused by the earlier removal of another makers software from the operating system. To solve the problem, first disconnect the camera then follow these instructions to copy the appropriate file from the Win98SE CD back to the correct directory on your computer: Place the Win98SE CDROM in the CD-ROM drive. From the Start Menu select Run, type in SFC.EXE. Select "Extract a single file". Type in IMAGEHLP.DLL to the field provided. Click start. When the next dialogue box appears click "skip". This dialog box appears: Where e:\WIN98\ should be the Win98SE CD-ROM (your CD-ROM drive may use another letter other than "e"). Copy the file to the same destination shown and a screen will appear showing that "File has been successfully extracted". Next, remove the Win98SE CD-ROM from the CD-ROM drive and replace the Nikon View 5 CD in the CD-ROM drive. Reconnect the camera. The hardware wizard should automatically detect the camera and install the driver from the Nikon View 5 CD.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
