Drum rattling - Washing Machines
  • Ian Jones
    Ian Jones Apr 20, 2015
    Problem was that one of the drum support bearings was worn.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Could b bearings
Posted on Apr 19, 2015
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Loose wire from clothing rattling in between drum and drum housing
1.Turn your machine on its side and study how to 'unscrew the drum assembly 2. Fashion a guy wire and make a hook and if your lucky you might 'fish it out ,good luck.
Dec 26, 2011 | Hoover Washing Machines
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
Found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
Apr 26, 2010 | Kenmore HE5
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
Loud rattling sound, drum still turns
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 12, 2009 | Miele T9800 Electric Dryer
Beko wm1510w bearing?
Hi there.....this rattle can usually be associated with failed or failing bearings.......simple test to follow....with machine switched off and door open...put your hand in and try lifting the inner wash drum...there should be NO MOVEMENT...movement indicates failing or failed drum bearings
regards Sir Galahad
Nov 09, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Rattle on fast spin
Hi mate the rattle could be caused by a coin are a bra wire regards a coin you would have to take off the main pump hose connected to the drum our else take the heater element out and see if you can find it if it is a bra wire just rotate the drum until you see it and pull it out
Jul 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Rattling
Level the drier, check the drum for foreing objects, check your belt and replace if need to. Check your rear drum seal, and your drier idler pulley, and replace if need to.
Jul 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
