This E9 error message keeps appearing. Have cleaned the bobbin area; have unplugged and restarted the machine. When I start o sew, it races for 10-20 stitches (as if out of contol) then stops. How do I resolve it ?
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
SOURCE: janome 8080 computerized sewing machine
Is the bobbin the correct size? if you have spare bobbins do they all have the same problem?
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
SOURCE: I have a Necchi 537FA sewing machine. It sill sew
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
SOURCE: Bernina 820 Tension Error Message
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
