What is the procedure on replacing batteries - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 47,630 Answers
Remove old battery from the unit after taking off the cover and unplug the battery and put in the new one . put cover back in place
Posted on Apr 19, 2015
What tools are needed to replace BCM?
Important: Perform new BCM setup when you replace Body Control Module (BCM). Refer to Body Control Module (BCM) Programming/RPO Configuration .
Disconnect the battery ground (negative) cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
Remove the left instrument panel insulator. Refer to Instrument Panel Insulator Replacement in Instrument Panel, Gauges and Console.
Disconnect the BCM electrical connectors.
Push the BCM up and move the bottom of the BCM away from and out of the mounting bracket slot in order to remove the BCM.
During Body Control Module (BCM) related service, the procedures below are designated to set-up the BCM correctly. Before you start, read these procedures carefully and completely.
Setup New Body Control Module (BCM)
Tools Required
Scan Tool (Tech 2) GM factory scan tool !
Important:
• Read this procedure carefully and completely.
• The BCM will not function properly if the Setup New BCM procedure is not performed.
• Perform the Theft Deterrent Re-learn procedure after successfully finishing the Setup New BCM procedure. If the Theft Deterrent Re-learn procedure is not performed after a BCM replacement, the following conditions may occur:
- The vehicle will not be protected against theft by the PASSLOCK system.
- The engine will not crank nor start. Your best bet is to take your vehicle to a dealer or a ASE certified repair shop who has proper tools .
Feb 16, 2016 | 2000 Oldsmobile Intrigue
2006 ford Five Hundred throttle body relearn procedure
Disconnect the negative battery cable, then reconnect when finshed with replacement.
Nov 15, 2014 | 2006 Ford Five Hundred
Trying to remove the battery from my 2007 soltice
Hello robert.... Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | 2007 Pontiac Solstice Convertible
Where is the battery located?
Battery Replacement
Removal Procedure
Lower the vehicle.
Remove the battery.
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure . 1737d1122299169-solstice-service-battery-replacement-procedures-158wilmingtoncarshow36.jpg
hope this helps . please rate my response.
Nov 28, 2010 | 2007 Pontiac Solstice Convertible
Battery replacment procedure- 2004 infinity fx 35
Get the replacement battery, remove the Negative terminal, then the Positive terminal, then the battery hold down clamps. Remove the battery and reverse the procedure to install the new battery.
Oct 09, 2010 | 2004 Infiniti FX35
How long does the original battery last? What is required to replace it since it is in a wheel well.
Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation.
To check a battery surface voltage, remove the positive terminal protective cover. Connect the positive side meter lead (red) to the positive side battery terminal. Connect the negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure). If the voltage is not up to specs, replace the battery asap.
Concerning the battery replacement procedure:
This is quite easy. The battery is located near the driver's front right wheel, just behind the wheel liner panel. You will need to turn the wheel all the way in to access the panel to remove the battery. I would raise the car, if possible, to make it a little easier. Raise the car and support the entire frame on support stands, if you can do that.
Aug 15, 2010 | 2002 Dodge Stratus
I replaced the car battery and the rear window wont go up?
The L/R Handbook explains the procedure to follow if the battery is replaced. Synchronizing the rear tailgate window is part of that procedure, along with the radio code and central locking.
Feb 23, 2010 | 2003 Land Rover Freelander
Need replace cmos battery on Compaq Armada E500
Please check the manual at this link for the proper removal procedure. In the manual, go to Removal and Replacement Procedures, and then to 5.10 Real Time Clock (RTC) Battery. It will explain how to replace the battery.
Thanks,
Lolita
Mar 05, 2009 | Compaq Armada E500 Notebook
2000 MITSUBISHI MONTERO BATTERY CHANGE
manufacturer does not provide a specific computer relearn procedure for obtaining proper driveability . if the battery was disconnected or replaced , driving the vehicle will enable the computer to preform a relearn procedure for obtaining proper driveability , driveability may differ from what you are used to until computer has fully completed the relearn procedure . cheers
Jan 09, 2009 | 2000 Mitsubishi Montero Sport
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
