Question about Drills
Drill will not work just makes a whining sound when pressed trigger
  • Drills Master
  • 932 Answers
Dave,
You probably have gears inside that have stripped. Check with the manufacturer to see if they offer a "Max Repair" option for repairing your tool. Often that might be the best option for you because sometimes you will get a warranty period after they send it back to you and sometimes they might even replace it with a re-furbished newer tool. Hope this helps!
Posted on Apr 23, 2015
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
Hi used my dual drill last weekend and it seemed fine went to use it this weekend and it dose not work ,both batteries charge but when you press the trigger nothing happens ,I have. Power all round the...
look at the windings in the housing and if they are black not bright brown they will be burnt out Also smell the motor and you will tell if it is burnt as it will smell burnt.
Jun 15, 2013 | Drills
How do I use a Vermont American #17192 Drill Press Stand? Anyone have an instruction sheet for this? I acquired one from a sale but am unable to figure out how to mount our drill onto it. Thanks.
Here you will see how the drill is mounted in the device. Position (b) around the handle and tighten it up untill drill seats firmly in place. Take a speed square, or normal square and eyeball or measure the drill to see if its straight. Use the alignment adjustment (A) to fine tune the drill to get the drill bit straight and square. Tighten up all the nuts holding drill in device and recheck the drill bit for straightness.. Put your work under the drill, press the trigger and lock into place to get the drill to constantly run without finger on trigger, pull down the press lever to drill your hole... Hope this helps!
Nov 02, 2010 | Drills
Drill is running but chuck is not turning, appears dis-connected ! Can still put drill bits in but no power to chuck when trigger pressed, although sounds and feels as if working.
This drill must have a morse taper shank on the drill itself and has to be tapped on w/ a soft face hammer to seat it on the morse tapered shaft on the drill. clean the taper really well on the drill end and the taper inside the drill chuck and tap together.
Mike
Oct 19, 2009 | Drills
Just stoped working
make sure that in the speed selector you are fully on speed 1,2,or 3...sometimes you can fall inbetween and then it will do that...otherwise you may have overheated the drill and will need to deal with Grainger or another auth. Bosch dealer for warranty...if they don't fix you, buy a Hilti
Mar 02, 2009 | Bosch 13624 24V Cordless Hammer Drills
Bosch Hammer drill GSB 16 RE doesn't work every time I press trigger
Check the brushes. the switch may have a short. Also, check the wiring from the switch, making sure there is no loose connections to the field. Definitely fixable. Lemme know Please rate me
Oct 04, 2008 | Drills
Dewalt 18 volt compact drill
yes this is normal the spark keeps motor from stalling out by taking away the friction spark by making own spark
the clunk is the drill brake so you dont brake your hand when screw goes in all the way unlike old drills that kept going even when your hand was attached to it
Jun 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
498 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
