Question about Frigidaire Refrigerators
Hi, My Frigidaire ref#LGHC2342LF is not disensing ice cube or crushed. Water is fine. Ice is made but when pushing to dispense nothing (not even a motor noise). Any recommendations ? TIA
  • Official Brand Answer
  • 2,267 Answers
I appreciate your inquiry, friend!
From what you have described your Frigidaire refrigerator is not dispensing ice but it is dispensing water. Since you are not hearing any noise it sounds like you could have a problem with the auger or motor. I would recommend consulting with a professional technician for a proper diagnosis and repair to be completed. This will prevent you from purchasing any unnecessary part purchases. I hope this information is helpful to you. -Matt
Posted on Apr 22, 2015
peyton32034
  • 410 Answers
SOURCE: ice despenser
your refrig has a solenoid that opens and closes a flapper in the bucket to bypass the ice crushers look on the bottom of the ice container and there is a brass rod that is bent at the end. if yo will find where the end of that rod inserts into the dispenser motor inside the freezer there is a saddle that has most likely frozen in the up position. you can use a hair dryer to warm the area up and pull the saddle back to the down position. its kind of hard to tell you with out pics but hopefully you get an idea of wht i'm trying to describe..
Posted on Jan 07, 2008
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
samrat_babui
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
  • 192 Answers
SOURCE: I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Posted on Jan 09, 2010
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge gss fridge,ice dispenser problem.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. The crush position is without the solenoid energized. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Your solenoid is part 45 and the linkage to the crusher is 46. The crusher is 41 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239793#d1239793
Feb 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Model GLHS68EGSB2, ice maker will only dispense crush ice even if you press the ice cube dispenser
You need to take out the ice bucket, empty it, let the bucket sit in the sink for a few hours. Ice builds up in the crushing blades and jams them, let all the ice melt out of it and it will be fine
Oct 27, 2009 | Frigidaire Refrigerators
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
75 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
