Question about Frigidaire Refrigerators
Several times a day, my Frigidaire Refrigerator, Model # FRS26H5AS leaks water from underneath onto the floor. Usually it leaks about a cupful. Any ideal as to why, and how it can be fixed?
    Top Expert:
  • Frigidaire Master
  • 46,218 Answers
There is supposed to be a plastic pan there to catch that water so it can evaporate when the fan runs and blows air across it .
Posted on Apr 19, 2015
  • Wlh Alleman Apr 19, 2015
    wow, thanks so much! now I just need to find the part number for that pan!
  • ray gallant Apr 19, 2015
    almost any shallow pan will do
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
Occasionally the ice cube maker overfills causing the water to fall to the frezzer floor and leaking onto the ground, any suggestions on how to fix this?
Are you sure its the icemaker overflowing? if it is, you will have icycles on all the shelves and the food leading down to the floor of freezer. If you have NO icycles between bucket and floor, you have a clogged defrost drain problem.
If you do have icycles between bucket and floor, you will also have a big block of ice in your ice bucket. without personal inspection, i would advise replacing both the ice maker and the water valve(s)
Mar 18, 2010 | Frigidaire FRS26H5AS Side by Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Defroster drain leaks into the main compartment
The drain hole is plugged. Probably with ice now. Needs to be fully defrosted with a heat gun or hairdryer, be sure drain is free by pouring hot water into it and seeing it get to the pan below the machine. If this persists you need to troubleshoot the automatic defrost circuit. Could be bad defrost timer.
Sep 01, 2009 | Frigidaire FRS26H5AS Side by Side...
Water is leaking onto the floor from underneath. i bought a lot of vegetables yesterday and the refrigerator was really full - could that have caused it? what to do? thanks for any suggestions you have!
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Aug 12, 2009 | Frigidaire FRS26H5AS Side by Side...
Leaks onto floor
your defrost drain is stopedup if its a sxs its in the back bottom of freezer side if its a top mount its behind the back over in the freezer remove and use hot water and blowdryer you will see a little drain tube under the evap coil
Jul 05, 2009 | Frigidaire Gallery Series GLRT218WDZ 30"...
Fridgidaire Defrost Water Pan
i found my drain tube was not draining into drain pan, but onto floor
May 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
99 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
