Wash cycle never ends.
I have just reset the unit. Yesterday I took the filter apart and cleaned it, also checked fill and drain lines. The wash cycle will run for a few mins then pause and then restart. This sequence continues until I press cancle.
    Top Expert:
  • Washing Mach... Master
  • 52,166 Answers
Timer needs repaired or replaced
Posted on Apr 19, 2015
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
Mar 03, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
My Kenmore dishwasher does not drain out, What could be the problem?
No drainage, or poor drainage issues are usually caused by either a failed drain pump, or the sump area under the sprayer is clogged with debris. The sump is the area at the bottom of the tub where water collects on the initial fill. A wash pump cycles the water throughout the wash cycle, followed by the same water being drained from the unit by means of a drain pump. This area is usually covered by a coarse screen and fine screen to prevent debris from accumulating. But, over time, some debris may still get past the screens and collect in the sump. This usually results in poor cleaning results due to restricted water flow through the spray arms, and poor draining.
I would recommend you remove the lower spray arm and screens and check the sump area for obstructions. If the unit still has standing water inside, use a wet/dry shop vac to drain. Remove the drain line from your sink and pull a vacuum on the end of the dishwasher drain hose. If the water drains freely from the unit, then you probably have a bad drain pump. If the water will not drain, you have a clog somewhere. Check your drain lines and pump for obstructions.
If you have any questions, please post back with a MODEL NUMBER. I hope this helps you.
Aug 15, 2011 | Kenmore Dishwashers
The bleach and softner dispenser does not work. The liquid softner would still be there at the end of the wash - never dispensed. I took out the dispenser and cleaned it, but no change. When I leave the...
Don't know if this is the answer, but my dispensers stayed filled also. repairman said the water wasn't flowing into the machine quickly enough and therefore not tripping the sensor that told the machine when to disburse the softener and/or bleach. He took the cold watersupply line loose, and the mesh was full of sediment. He said it wasn't necessary to replace the mesh. Sure enough, it started working immediately. He did the same for the hot water line..it wasn't clogged.
Aug 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Intake/Drain red light comes in and shuts down during wash cycle
You will more that likely have a faulty waterproof inlet system
May 17, 2007 | Miele 24 in. Novotronic G851SC Plus...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
