Question about Miele Vacuums
Miele S8310 vacuum cleaner after working for about 3 min lowers suctions to its lowest setting by itself and I can't change it. Changed filters and bag but still the same.
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Posted on Mar 06, 2008
Miele s8310
probably a cord problem
Dec 10, 2017 | Miele Vacuums
How do I dismantle a Miele S8310 vacuum cleaner?
if the service agent states that it is not cost effective to repair then trust that advice
They will know of the difficulty to get it apart , the lack of spares when you do break it apart and the safety risk that is posed by repairs by untrained people
many wholesale cleaner shops have regular sales where the price of a new unit will be half the repair cost of an old unit
Apr 15, 2016 | Miele Vacuums
Hi This SBD 285-3 floorhead is for a miele s8310
Hi There,
I have to say i do warranty repairs for Miele and own VacuumSpot.com.au and I have actually never heard of this before either. The miele SBD285 is basically a good quality 35mm floor tool have you tried using a different type of tool. Wessell Werk (german manufacturer) make tools for Nilfisk, Electrolux etc make a range of tools and you may find that a different one will work perfectly for you. I am not sure where you ive but highly likely your local vacuum store will sell a version like this one which is truly excellent
http://www.vacuumspot.com.au/deluxe-german-35mm-combination-floor-head-ftw135-2
Sep 17, 2013 | Miele SBD 285-3 Classic Combination...
My miele has no suction and i changed the bags
99% of the time you can fix this problem with a new filter i have put the link in for the filter for your vacuum cleaner if you have changed the filter in the last 3 months then you might have a blocked hose check the hose first then get yourself a new filter
Miele filter for s514
Jun 04, 2012 | Miele S514 Solaris Bagged Canister Vacuum
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Nov 07, 2010 | Miele S548 Bagged Canister Vacuum
My miele vacuum cleaner hose has no suction
have you tried changing your filters.? Also using genuine filters gives you much better suction
Feb 14, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My S 7000 upright vacuum red carp light on
its probobly the belt is broken
Sep 08, 2009 | Miele Vacuums
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele vacuum cleaner not working properly
Mar 05, 2008 | Vacuums
Vacuums Logo
70 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
