Question about Refrigerators
The evaporator fan motor start and stop continuosly
  • 960 Answers
You could have a bad connection between the fan motor and the connection inside the freezer, or it could be a faulty door switch or the fan motor itself is faulty.
Posted on Apr 19, 2015
4 Suggested Answers
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
SOURCE: Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Posted on Apr 28, 2009
machinetech7
  • 1344 Answers
SOURCE: Evaporator fan motor wont start
WR60X10220 is the part number to the evap. fan motor if your complete model number is this STS22ICPBRWW, which you can verify by locating the label on the machine somewhere and on a label you actual model with serial number will be listed. The Fan motors start winding has gone out on it and when you spin it you're taking the place of it giving the run winding a chance to kick in. This part should run anywhere from $20 to $30 bucks.
Posted on May 10, 2012
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Frigidaire model frs26rlecsg star and stop continuosly the evaporator fan motor
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Apr 19, 2015 | Frigidaire Refrigerators
Evaporator moter wants to start (BUMPS) ,will not run,Motor is free
System froze because the fan motor stopped working, could be that the fan motor is bad, or if it is a PSC it could be a bad capacitor.
Jan 10, 2013 | Heating & Cooling
My fridge upper unit isnt working, there is no air circulating, i could hear the compressor working and it seems the lower unit is fine. it started by making a constant ticking sound and then a day later,...
You will need to look into the possible chance that your evaporator Fan motor has stopped, been damaged or the freezer is not defrosting properly. To allow it to continue running can damage the compressor. Click Here=> MFD2560HES Evaporator Components then 12002744 Evaporator Fan Motor and again the 67002493 Defrost Heater I have all the instructions and hands on if you would like my assistance I will be here to assist and repair you Maytag That ticking noise could have been your fan blade finally reaching the frost until the fan stopped. Let me know Here or or here on Fixya, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MFD2560HES Bottom Freezer French...
The fan is producing continuous sound. looks like the fan is not rotating. It stops for a while and then, in couple of minutes, it starts again.
Hello and Welcome to FixYa!
This usually happens, if there is excess choking from ice in the evaporator coils...The excess frosted ice in the chamber extends to the evaporator fan, thus trying to choke/stop the fan... Whenever the fan gets start pulse from the controls, it hurdles the movement and the noise comes. Remove the blockage to the fan (if any), else you need to change the fan motor bearings...
Best of Luck,
Please Do rate the solution, if Found Helpful,
Concerned.
Sep 18, 2010 | True GDM-49-RC Refrigerator
Freezer fan motor making a louder hum noise than usual.
If the refrigerator was closed for a while before plugging the power back in moisture that was left inside the refrigerator will cause the evaporator fan motor will rust on the ends of its shaft. I don't believe the motor is going bad. Usually when that happens they will run for a while and stop or just stop completely.Sea Breeze.
Sep 23, 2009 | Kenmore Refrigerators
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
Apr 28, 2009 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
