Question about Pool & Spa
Can you advise me how to increase the temp in my hot tub? Jazzi SKT338H. It seems to be working properly but I don't have the manual anymore
  • 1,631 Answers
Either turn heat control dial up, or there should be a 2-button, one UP & another DOWN. Push UP button.
If a single Heat button, the push the button once, it will start to blink, then push again - if temp goes up, you are going in the right direction to get to your desired temp. If going down, then stop & wait till blinking stops - then push the heat button again, it will blink again, press again and now it should go in opposite direction.
Posted on Apr 20, 2015
Dose not heat
check temp sensor
Jun 17, 2014 | Intex Pool & Spa
How can i increase the tempature of my oasis hot tub from 101 which seems to be max to 105 degrees
That is not adjustable. It is set from the factory and the manufacture has to legally limit the temp for medical reasons. The tub I had and the highest temp allowed by law is 104 degrees I believe.
May 03, 2014 | Dryers
I have just replaced my circuit board (balboa 53247) for my eclipse hot tub and as soon as I plugged the unit in, I got an OH reading from the top-side control. Then I noticed that if I pulled the temp....
Unfortunately, I would have started with the sensors and then escalated from there. A hot tub is one of those items that I generally recommend hiring a technician to sort out, it's just flat not worth the headache of troubleshooting without the know-how.
As for your particular problem, the OH code on a Balboa control pack is "O.ver H.eating" it means that the heat sensor detected high temp and shut down to prevent damage to the system (as well as cooking you like a pink lobster) The sensor could be bad or the control board could be malfunctioning. A new sensor is $75-85 if memory serves me and is relatively easy to replace. one sensor is in the heating tube and the other is screwed into the tub shell to monitor tub temp. I would suggest new sensors, both of them because when one goes out the other usually isn't far behind. Make sure you shut the power to the tub off at the breaker box before doing any kind of tub repair. If you have shutoff valves on your tub you can replace the internal one without draining the tub. the one in the shell you need to drain to replace (at least to the sensor hole level) I hope this helps you to get your tub working properly again, if you still experience issues after this, I suggest biting the bullet and calling in a tech. Thanks for your question =)
Oct 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Balboa hot tub.. how to turn up the HEAT / TEMP , no owners manual, and does anyone know where I can get one?
You do not have a Balboa Hot Tub. That is the company that made the control panel for it. Id venture to guess it's either a Hawkeye, Barefoot or Master spa if it came with no owners manual. To turn up the heat simply press the Red "up" arrow on the digital control pad. Check out the link below. It's a quick reference guide to what I'm guessing is your top side control.
http://www.hawkeyespas.com/pdf/balboa-504-topside.pdf
Apr 22, 2013 | Garden
Overheats after running about ten minutes...doesn't overheat while idling.
Seems like your thermostat is going out, meaning that it is not opening all the way anymore, at idle its not a problem, no hi RPM on the motor, but as you rev up, temp increases, thermostat not opening all the way obstructs coolant flow so the block does not cool off properly.
Another thing to look at is your water pump, is the fan clutch working properly?
Obstructed radiator, it may need a good flush.
The car is over 10 years old, so expect it to start having issues. I'd advise to check your ******, do a maintenance on it. (filter and fluid change)
Aug 19, 2011 | 1998 Lincoln Continental
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
We just bought a qca topaz hot tub from a person and we can't seem to get the jets to shut off. Any ideas?
reset the filter timer on the unit probably set at max since being powered up [replugged in ] 6hrs out of 12hrs every 12 hrs if u have manual will explain how to set temp and filter run time if no manual can notify company and they can advise --i believe on yours that if u hold down the light button for a few seconds it will flash a number and u can use up and down adjustment arrows to reset time usually set at 1
Aug 12, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Moen posi-temp valve with little pressure
no,, they are set with water savers, they only flow aprox 2.5gpm this is the top flow,, if you have it more on hot you will get less flow bings it is temp control and won't let you burn your self,, nice thigs the government does,, the only other thing you could do is go back to the old style 2 or 3 handle diverters, but we all know nobody wants them anymore, good luck
Apr 03, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Pool & Spa Logo
71 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
