Question about Indesit Washing Machines
Indesit wia 101 stuck on one part of cycle and won't move on
My machine is stuck on one bit of the cycle it starts the cycle fills the washing powder draw with powder and then it just keeps going back to repeat this . It never moves on to taking in the fab con or spinning. How can i reset it so it can move on please ? Any help would be greatly appreciated
    Genius:
  • Indesit Master
  • 1,585 Answers
Check pump for blockage remove plug for 15mins re try
Posted on Apr 19, 2015
  • Anonymous Apr 19, 2015
    hi tom thanks for your reply do you mean the plug for the elecricity or the drain plug sorry maybe a daft question.
applianceboy
  • 77 Answers
SOURCE: washing machine is not spinning, and getting stuck mid cycle
Check the maytag class action suit in reguards to the neptune issue. you may be entitled to an exseptional warranty call based on this reguards. there is a problem with both the wax motor and the control board.
Posted on Sep 25, 2007
  • 1294 Answers
SOURCE: INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Posted on Jun 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Posted on Jan 23, 2009
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a indesit WIB 101 (uk) washing machine.
Remove the belt, and from the front, spin the drum by hand.
If it is noisy or rumbling or feels rough, then the main drum bearings have failed which would explain why the belt was off.
Also check the drum pulley for a brokem or cracked spoke, again this will give you the same symptons.
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
I have an indesit wia 101 front loader washing machine. At the moment it will not drain or spin & the red light flashes really quickly
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Indesit W 123 Front Load Washer
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
Indesit WIA 101 Machine wont start.No power
first check the fuse,if this is ok,you will require a main control board,this will require programing for you model and comercial code
Jul 25, 2009 | Indesit W 123 Front Load Washer
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Door gasket damaged
Have you sorted your problem out yet?
You can get any spares you need by going on line to:www.hotpoint.co.uk, and followning the links.
Good luck.
Dec 02, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 101
to open do power off after 5 min open the door with power off
Jul 27, 2008 | Indesit W 123 Front Load Washer
INDESIT WIA 101
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Washing Machines Logo
209 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
