Question about Ovens
Bottom oven does not work
Having replaced element After it packed up knocking out the house trip but there is no power to bottom fan or element. Top oven is fine.
  • Ovens Master
  • 5,323 Answers
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Posted on Apr 22, 2015
Why isn't my oven working? After changing bake element and thermostat
Either the bottom element is defective or the wiring to it is not hooked up properly so it gets power and does its job ala the top element.
OR the control that is responsible for having power delivered to both elements is only sending power to the top element. Make sure you are not using the broil setting since that only activates the top burner.
Feb 03, 2016 | Ovens
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
I turned the bottom oven on and it was like a small lighting bolt went off, it tripped the fuse box to the house and now only the top oven works?
You will probably find that the element for the lower oven has expired. They sometimes do go in a shower of sparks. I once had an element on a hob explode in my face and a small lump of red hot metal flew up and just missed me.
It is easy to get to the circulatin fan and element, you just have to remove the 4 self tapping screws in each corner of the fan/element cover for the cover to come off. If the element has burnt out as you say you should see some evidence of burn marks/holes on the element.
The bad news is that you will have to take the whole oven out of the housing to remove its top and back to gain access to the element retaining nuts and the wiring to unclip/reclip it.
Try espares for a replacement element and if it was a major bang when it went, you should consider replacing the thermostat as well as this is often damaged by the element going.
(The thermostat is the long thin metal rod in the top right hand corner of the oven and is connected to the control by a very thin fragile pice of wire - be careful)!
Sep 06, 2010 | Stoves 720EF Electric Double Oven
Hi right my indesit 29229 fan oven is not working it blow the power in the house now the top oven is work but the bottom one wont heat up the fans working and thats it do you think its the element thats...
To blow the house trips it must be the element
Thermostats do not normally go short circuit.
The elements can be replaced quite easliy and cheaply
I would check that the fan is turning freely before you buy the element
Feb 24, 2010 | Ovens
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Botom oven not working
Hi
The oven element is probably faulty, I assume the fan is still working.
Nov 23, 2008 | Ovens
Ovens Logo
208 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
