Question about Miscellaneous
I have crack in my yonex carbonex 7000 plus racquet. How and from where it can be repaired? Near the name'dura frame' the crack is there.
    Top Expert:
  • Miscellaneous Master
  • 45,552 Answers
Try a shop/ sport shop the restrings racquets as some of them can also carry out minor repairs before they restring the item
Posted on Aug 03, 2015
2 Suggested Answers
iambanshee74
  • 3489 Answers
SOURCE: cracked frame near left front wheel
DO NOT DRIVE!! GET IT WELDED! this is too big of a vehicle to chance this thing not breaking. a reputable welder should be able to get the job done. the best place to get this done is a body shop. they will know how the metal is treated and the proper way to weld it without causing metal fatigue. happy holidays
Posted on Dec 24, 2009
Why is the inside painting cracking & rust is oosing out?
Hello Miriam;
My name is peter. I am a retired field service appliance technician.
The reason your micro wave liner is cracking is the way you place the food in the microwave.
The rust is coming from the steel frame where the liner is cracked.
Go into the following video on how to repair the cracked liner. You can do this.
How to Repair Microwave Arc and Burn Marks Touch Up Paint
Apr 04, 2016 | Magic Chef Microwave Ovens
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
How we can repair the broken badminton racket frame....
The only thing to do is replace it unless it's a hairline crack, which may still result in a larger crack over time, especially after each stringing.
Aug 11, 2013 | Boardsforless Yonex SRQ Ti-600 Long Tennis...
Are there different head sizes for a tennis racket?
there are 3 different head sizes of rackets. here is an explanation of the different sizes from http://www.dummies.com/how-to/content/choosing-a-tennis-racquet.html
Over-sized:
Beginners really like the over-sized and even jumbo frames, which offer between 100 and a whopping 140 square inches of strung surface. Such frames give you a larger sweet spot simply because the hitting surface is bigger, and they allow you to hit the ball farther from the heart of the sweet spot and still make a good shot.
Mid-sized: These racquet heads range from 85 to 100 square inches. Most pro players use frames on the low side of mid-sized - between 85 and 95 square inches. Most recreational players gravitate to the high side of mid-sized - between 95 and 100 square inches. Mid-size racquets offer a great compromise between a larger strung surface and sweet spot and a maneuverable frame that lets you generate good racquet speed when you swing.
Standard-sized heads: Ranging from 80 to 85 square inches, standard-size heads are now obsolete. They give you a smaller strung surface and sweet spot, making it more difficult to produce crisp, clean shots.
Feb 20, 2013 | Sport & Outdoor - Others
Rear dura ace brake pad rubbing on left rim
Adjust it or true the wheel or mount the wheel correctly in the frame/fork.
http://www.parktool.com/blog/repair-help/sidepull-brake-service
May 20, 2011 | Cycling
I dropped my iphone and my screen is now white can i fix this ?
The iPhone screen is not too hard to replace. A good source for the part would be ebay. Thereis a step by step guide too that explains how to replace the part : iPhone repair guide. There are also third party companies that do it for you : iPhone Repair NYC
Nov 16, 2009 | Apple iPhone 3G
Kitchen Aid side-by-side refrigerator making dishwasher sounds
The freezer door frame should be warm where the door seal is located. This is to keep the rubber seal plyable and to prevent the door seal from freezing. Could it be that the cold seal is not properly mating with the frame and you are hearing the fan noise through the crack ?
Aug 05, 2009 | Refrigerators
19'' durabrand tv codes
no a rca universal remote will not work with a dura brand tv u can go to walmart and ask some one where is there the remotes that works with dura brand usely at my walmart there near the checkout points near the cand and magazines
Nov 15, 2008 | Durabrand BH1304D 13" TV
Miscellaneous Logo
Top Miscellaneous Experts
Valmae Patterson
Level 1 Expert
cwcollectr
Level 1 Expert
Andrew Jumba
Andrew Jumba
Are you a Miscellaneous Expert? Answer questions, earn points and help others
