Question about Magic Chef Refrigerators
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
  • 960 Answers
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Posted on Apr 19, 2015
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
SOURCE: Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Posted on Aug 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: my mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Posted on Aug 27, 2009
  • 396 Answers
SOURCE: My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Posted on Oct 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: Magic Chef Compact Mini Fridge Model
Might just be the compressor relay. They had a bunch of them go bad in recent years. I have repair photos HERE
Posted on Jan 10, 2010
Mini beverage fridge. runs. wont cool. Model number MCBC58DST
probably bad compressor or sealed system problem.
Oct 14, 2013 | Magic Chef Refrigerators
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
I have a Magic Chef Mini Fridge model number MCBR465S that stopped cooling. I can hear it humming but don't know how to diagnose the problem. The seal on the door is a little bent up (not really bad) on...
the humm may be the compressor trying to run . the seal is not your problem / but if you get it running then i would replace the seal . . the relay on the compresser could the problem. also the fan underneath if not going this would cause the problem. hope this helped mm
Oct 24, 2010 | Refrigerators
First fixed the seal make sure that any leaking out. And then go to the next step by checking to see if the compessor motor come on and stay running for af list 10 minute. check the temperature controls make sure they are at the set temperature.
If you go behind the fridg and take the motor temperature see is very hight you must unpluged the fridg you may have a bad motor.
Oct 24, 2010 | Magic Chef MCBR445S1 Stainless Steel...
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
Oct 20, 2009 | Refrigerators
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerators Logo
221 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
