Question about Bose Audio Players & Recorders
I have a bose lifestyle V25,but i want to make additional subwofer i have one extra PS18 iii subwoofer what kind of cable to buy to make additional subwoofer of my lifestyle V25
SOURCE: Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Posted on Apr 09, 2008
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
cjackHD
  • 71 Answers
SOURCE: bose lifestyle fault code 802
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
Posted on May 31, 2009
MarineTech1
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
pabloloco
  • 2335 Answers
SOURCE: I have installed the v30 bose lifestyle system but...
I recommend you stick with component cabling.
Having no picture at all generally suggests the V30 is trying a video mode your TV does not support:
  1. video type (PAL or NTSC)
  2. Progressive scan
  3. an HD resolution beyond your TV's range.
I hope that helps.
_______________________________________
Download Bose LifeStyle V30 User Manual
Posted on Jul 05, 2010
How do I test the Bose ps28 3 sub woofer without any other bose components?
Thats a toughie because that system is well..a system. They build those so that each component runs through that main circuit board there and then thru the outs on the sub--I would look for a used player that you can hook it up to or pass on it.
Jan 24, 2015 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
Need to replace pigtail fuse
This may not be a fuse. Bose uses devices like this as "speaker protection". If this device is wired to the woofer, that is exactly what it is. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
I need some help. I have a Bose V25 lifestyle system and I need to know how to run the cables from the Bose system to the AT&T U-Verse cable box. Thank you!
It looks like the easiest way to do this is to connect an HDMI cable from the U-Verse box to one of the three HDMI inputs on the V25.
Note: There is also an HDMI output on the V25. Don't use that one. (It's labeled "Output".)
Jul 24, 2013 | Audio Players & Recorders
Hi, I am working in US and planning to buy Bose V25 and take it to India. Please help me with following clarifications I have. Is Bose V25 system region free?. Is it going to work with both PAL and...
Hi,Did you get solution to your problem?If so let me know..Even we bought Bose V25 and planning to move it to India..did you face any problems else evrything worked out good for you?your answer regarding my problem is very precious..please reply me..
Jun 12, 2011 | Bose Lifestyle V25 Theater System
I have the lifestyle v25 system but my wife does not want to use the bose sound all the time. She says she doesn't need 5.1 when watching hgtv. Can you help.
Help how? Change her mind?
If the TV has speakers and IT has basic audio coming in directly from your (presumed) Cable Box, use the TV speakers.
May 25, 2011 | Bose Lifestyle V25 Theater System
LIFESTYLE 28 Series III System: i have unique problem. My TV is connected to Bose ...
i would try changing ports right at the lifestyle unit ...make sure the port is good
May 18, 2010 | Bose LIFESTYLE 28 Series III System
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Sep 11, 2007 | Bose Acoustimass 10 III System
60 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
