Question about Fisher and Paykel Kitchen Ranges
Fisher and Paykel cooktop is beeping with number 4 appearing stove top display
The stove top has been having a loud beeping noise occurring every couple of minutes. The digital display show number 4 on the 4th Burner electronic display - ti have also effected the ceiling lights in the kitchen when it beeps!
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel CE901 36" electric
Sorry, I don't have a solution, but a similar problem. My CE901 is 6 years old. One of the regulators broke after one year. The repair (under warranty) caused an electric fire a couple of weeks later. After much complaining, I got a replacement cooktop from F&P. Now, 5 years later, one regulator stopped working, no longer turns on the element. (I guess that's better than no longer turning it off.) You are not alone. Seems like F&P is incapable of producing a simple regulator that works reliably.
Nov 28, 2010 | Fisher and Paykel 36 in. CE901 Electric...
My fisher and paykel WG708 top load washer fills with water. No rotation of the washer occurs. No machanical sound happens. 4 lights stay on and makes beeping noise. Water will drain but no spin happens?
Hi just read your posting.Could you confirm the model number for me,Is it GW708?Now the lights that stay on when the machine is beeping will be in a row of 8 lights.Starting from left to right which ones are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Aug 06, 2010 | Fisher and Paykel Washing Machines
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Gas cooktop igniting and lighting but when you stop the igniting the gas does not stay lit
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Feb 14, 2010 | Fisher and Paykel GC36 Gas Cooktop
Fisher and Paykel top load gas dryer makes very loud noises.
You may have something stuck in the blower wheel, or more unlikely something stuck in the bearing(s). Will need a Tech to come out.
Apr 22, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Apr 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kitchen Ranges Logo
53 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
linnap
Bob Kirkwood
J D Wright
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
