Question about Garden
What is mix of petrol/oil for a performance power pro24ccsgta
  • 991 Answers
50/1
Posted on Apr 19, 2015
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
I have an aprilia rx125 2008 & the oil petrol mixing system has been blocked off and now petrol & oil are mixed in the petrol tank, but the bike starts for 3-5seconds then stops & petrol comes out of
Hi Steve, and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2008 Aprilia Rx 125
Dec 04, 2011 | 2008 Aprilia RX 125
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
Garden Logo
99 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
