How can I speed up the running of my Mac? When I switch it on it takes ages to boot up.
I have tried running cleaners but they don't seem to help, unless of course I am using the wrong ones. I do have a lot of photos stored on it but not many other documents. It is used mainly for the internet. Any advice would be most appreciated. If you need any more info please ask :
  • 1,602 Answers
I have a program call winpatrol, i think they make it for mac, go to the website look at what it can do for you and i recommend buying the plus upgrade, you only have to buy it once and it last a life time of support, and if your not sure of a progran select the program in the search and you get all the information if the program is good or bad.
Posted on Apr 19, 2015
I have an EEE PC Netbook running on Windows XP (not sure what Service pack, maybe 2?). I have the discs that came with it, etc. The issue I have is that the Hard Disk is partitioned into 2 sections. I...
The 2nd partition (D:) may be your Factory Recovery Partition? How large is it? I would do a Cleaning and some Tweaking of the Laptop first. Use these two Freeware programs to help with the cleanup. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ Run the cleaner, look at the Applications tab to customize your cleaner, Runthe registry cleaner, delete all results, Open the TOOLS section, select the STARTUP section, disable ALL unnecessary startup programs to speedup start and running, Use the UNINSTALLER to remove Any/All unnecessary programs. 2, download freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot. Run a FULL scan with your up-to-date Anti Virus, delete ALL results. Do ALL your Windows Updates and Laptop Manufacturer's updates. Use this procedure for more Speed Up/Cleanup tips: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer Can you open the 2nd Partition? What's on it?
Apr 07, 2013 | Computers & Internet
Tip
Speed Up Windows XP Boot and Shutdown Times
This guide will show you how to shorten the time it takes for your desktop to appear when you turn your computer, and make it shut down faster as well. Here are a few tips to get you right to your desktop as quickly as possible after startup.
To speed up Windows XP shutdown times:
Turn off services that you don’t need. If you want XP to shutdown faster, you need to have less services running for it to shutdown. Disable any unneeded services.
Don’t clear virtual memory at shutdown. Clearing the page file can provide more security, but that comes at the expense of speed. I don’t really care if someone can look at my page file. If you are more concerned with the shutdown speed, then you will want to disable this option in the registry. You will need to locate the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management registry key and change the ClearPageFileAtShutdown to 0.
To speed up Windows XP Startup times:
Waiting for your computer to boot can be a painful process. Though Microsoft has taken steps to speed up the boot process, it still can be improved. Here a few suggestions you can follow to speed up your Windows XP boot time.
Boot Defrag. If your boot files are closer together it will take less time for your hard drive to seek the files, therefore giving you a faster boot time. This was enabled by default on my machine, but you will want to make sure you have the option enabled in the registry. In HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction
You will want to set “enable” to “Y”.
Keep the registry clean. Windows registry can be a disaster. When programs install they will create registry keys. When you uninstall the program it will leave behind useless registry keys. The solution is to use a good, reliable, registry cleaner. Be careful in which one you choose though because a bad cleaner could really screw up your system. My favorite choice is CClceaner, which will also rid your machine of some spyware and temporary internet files. You can download it here.
Change BIOS Settings. The computer has to go through the BIOS before actually touching Windows. Changing a few settings can decrease the time it takes to actually get to the Windows XP boot screen. First you will want to run a Quick POST (power on self test) if your bios has this option. Secondly you will want to disable booting from a floppy (especially slow), cd, usb. If the BIOS only has to look for the hard drive it will go much faster. You will want to remember that you changed this setting though, incase you have to boot from one of these devices for troubleshooting. The last option is to turn off Boot Delay if you BIOS has this available.
01011010 G.I.G hacker 0100101
www.gighacker.blogspot.com
on Feb 14, 2010 | Computers & Internet
Tip
Tips To Make Your PC Boot Up Faster
If your pc is taking ages to start up , then follow this advise to speed things along and get you going faster.
1. Uninstall Old Programs and Stop Unwanted Services From Starting.
The main culprit making a PC slow to boot is programs. If you have programs installed on your computer that you are no longer using , you should remove them.
These programs often have background processes running which not only uses your RAM but also takes time to load at start up.
A useful program I found is Tune Up Utilities. This program has a feature called start up manager which will allow you to stop unwanted programs from starting up when you turn on your PC. Not only that , but the software also identifies programs and processes which you should keep running. A free trail version is available HERE.
You can also do this in Windows Vista and Windows 7 by going to run in your start screen and typing in msconfig. Then go to the start up tab and deselect everything you don't want to have start when you start your computer.
If your run command is not visible , go to command prompt and type in msconfig.
2. Windows loading screen
You know that page with the animation? That takes forever right? You can actually remove it without much trouble and it will save about 10 seconds on your start up time. Here's what you do.
Go to run in your start screen and type in msconfig.
Go to the boot tab and select "noguiboot" checkbox.
This will cut the animation getting the computer to start faster. If you have a duel boot system , you can also set the timeout for that menu by making the timeout 3 seconds instead of 30 seconds.
3. Defrag and clean the Registry
Download a free program called CCleaner (HERE) and install it. This program will remove invalid registry entries. This will mean less time that the computer is looking through registry keys and thus improved start up and system performance. Just click "run cleaner" and it will automatically search for and remove invalid keys.
You may also want to defragment the registry. Open Tune Up Utilities and select all functions under the first window called "maintain system" and select "defragment registry".
This will also help a little for system performance and start up time.
4. Edit Your Bios
The bios by default contain some options that are redundant and can be switched off to save on start up time. For instance :
  • Make your first boot device your hard drive.
  • Select Quick boot or "do not check memory"
  • If you are using a graphics card , disable the on board as it's only using memory.
Following these few steps should save you about 30-45 seconds on start up and improve overall system performance.
Please rate this solution if you found it to be of help.
Stephan
on Feb 02, 2010 | Computers & Internet
I restarted my new macbookpro. now it wont let me open Final Draft. When I try to open in, the Mac Automator comes up and seems to shut down Final Draft. Please advise.
Thanks for visiting FixYa!
First, uninstall Final Draft 7 from your Mac. Then re-start your notebook. After it boots up - run a registry cleaner if you have one to remove all bad registry values that may have been let behind by the program. If you don't have a registry cleaner, try to get one. After running the registry cleaner, re-boot your Mac. Then, re-install Final Draft 7.
Two things might have happened. (1) the program became unstable and shut down or (2) you have a problem with certain sectors in your hard drive and lost part of the program.
In either event, re-installing it may cure the problem.
Apr 21, 2011 | Final Draft 7
How to upgrade my ageing drivers and hope bring back the previous speed of my computer?
Greetings,
Upgrading your drivers won't speed up your PC. Most system speed loss is due to fragmentation on your hard drive, malware, more programs running in memory and the state of your system Registry.
1. Defragmenting your hard drive. Make sure you have at least 10% of your hard drive free and open My Computer, right click drive C, right-click and choose Properties, then click the Tools tab and click Defragment.
2. Scan for malware. Download and run Norman Malware Cleaner from http://www.norman.com/support/support_tools/malware_cleaner/ Scan your entire drive C then click the button to repair the problems found on the bottom of the window.
3. Prevent unwanted programs from running at system boot. Click Start/Run then type msconfig and click Run. Uncheck any unfamiliar programs or programs you don't want running at startup, then restart your PC.
Apr 17, 2011 | Toshiba Satellite U305-S5097 Notebook
Imac 24 - running uber slow , trying to get to disk utility but finder is taking hours to load , everything seems totally jammed. Had to do a manual reboot and fsck proceedure this morning as it had...
Well, there are a variety of reasons that can consequently drag down the performance of your Mac. Meanwhile, there are certain ways through which you can considerably speed up your Mac machine. For example, you can reset the browser settings to regularly clear useless caches and history, get rid of all unwanted widgets from the dashboard through the Dashboard control panel, remove unnecessary applications, find out & delete those duplicated files, or if your Mac is running out of memory, try upgrading the system RAM to boost its performance etc. However, if you prefer a more efficient way to speed up your Mac, try the following all-in-one Mac speedup tool as it can help resolve all issues in just a few clicks.
Jul 15, 2010 | Apple iMac Z0CY Desktop
How do i unlock my laptop
If it takes ages to boot up and switch off, sounds like virus/malware infection.
Boot into safe mode with network support (usually f8 on boot up)
run a good malwate scanner like Malwarebytes(free)
Microsoft also has its Security suite that is free and has windows defender built in.
also CC cleaner is a good program for removing all the rubbish from your pc and for stopping unwanted programs starting up at boot up
Jul 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
I was trying to install Mac OS X 10.3 on my G3 iBook, it did not work, and now neither does the iBook.
It sounds like you have a hardware issue of some sort - likely a bad hard drive, due to age. I would suggest taking the laptop to a repair shop (don't bother with the Apple Store, they'll tell you to buy a new laptop or just turn you away). Best of luck!
Nov 09, 2009 | Apple iBook G3 Mac Notebook
I have a seagate 300gb external h/drive plugged into my mac book pro but cannot seem to play movies on mac book from external..help!!
You didn't say how you are connecting the drive. with a MBP you should be able to play the movies if the drive transfer speed is enough. Try moving the movie onto the desktop and playing it, if that works, then it's a transfer speed problem. If not, then you probably need the right piece of software to run it. I'd try VLC which is an open source player that takes almost any content type.
Sep 10, 2009 | Apple Computers & Internet
Can't boot up my mac book air
hm, try leaving it on over night, sometimes if you turn your laptop of from the power or hold down the power button when allot of programs are running or if you get the program not responding thing happen this can mess up your laptop and will take ages to boot up,
or it might never boot again
so you will need to take the install cd/dvd that came with the laptop, insert it into your laptop, reset it again, then as u hear that sound apples make as you turn it on, hold down C untill it boots into the cd/dvd then go from there.
Jul 02, 2009 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
