Question about Brother Sewing Machines
Sewing machine jam
How can I fix my sewing machine from jamming
    Problem Solver:
  • 16 Answers
If you mean that the needle has jammed with a build up of thread, then the only option is to cut the thread, raise the needle, if you can, and remove ALL pieces of cut thread. Sometimes if it's really jammed, you need to use a sharp knife, horizontally, to slice through the jammed thread.
The bobbin should be removed after this, and ALL traces of thread removed from all areas. Then, re-thread, re-insert bobbin, and try again.
Posted on May 02, 2015
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
  • 25 Answers
SOURCE: sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Posted on Jun 02, 2009
WonderTech
  • 268 Answers
SOURCE: keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Posted on Dec 30, 2009
  • 300 Answers
SOURCE: Sewing machine is jamming
The UPPER thread is not threaded through the machine correctly.
Posted on Feb 11, 2010
Testimonial: "That was part of the solution. I also adjusted the bobbin tension, together that solved the problem. thanks for your advice! "
  • 980 Answers
SOURCE: My Singer 507 sewing machine keeps on jamming up,
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Posted on Apr 09, 2010
Machine is jamming. Top thread broke so re threaded and re did the bobbin,but it is still jamming every time i try to sew
just found this on the internet...
Fabric jamming in your machine may be caused by the feed dogs. The feed dogs are those tiny teeth along the sewing machineunderneath the presser foot as those teeth pull the fabric through when the needle is making stitches.24 Feb 2016
Why Does My Sewing Machine Keep Jamming?•Sewing Made Simple
sewingmadesimple.net/why-does-my-sewing-machine-keep-jamming/..
or go to this link..
sewing machine is jamming Google Search
Oct 27, 2017 | Sewing Machines
I have a brother lx 2500 sewing machine and when it jamed i opened up the bobbin area and cleaned everything but now having problems getting the casing back in
Use a mirror and make sure that the area is perfectly clean and there are no obstructions. Then make sure that the needle is all the way up to the top of its cycle and then insert the bobbin.
Sep 20, 2015 | Brother Sewing Machines
Cutter on speedylock
Servicing the Timing is NOT a home fix
Mar 08, 2014 | White Sewing Speedylock 1600 Mechanical...
My sewing machine stops sewing and thread gets jammed underneath the fabric
Change your needle, and retread properly. then make sure you are holding the threads when you start a seam.
Sep 05, 2012 | Bernina Sewing Machines
Toyota 8001 has locked/jammed
since the machine has locked up & jammed the machine needs to be serviced, to see if a part is damaged & to see if the machine is out of time
Apr 14, 2012 | Toyota Sewing Machines
My Janome 6500p is having bobbin issues
here are my suggestions
1. when your sewing check to see if the thread is coming off the thead take up lever,, I've had this to happen to me & it can jam a sewing machine up
2. it's possible that the bobbin case is worn & needs to be replaced
3.also check your top tension
4. try rethreading the machine top thread & bobbin
Feb 06, 2012 | Janome Sewing Machines
Sewing machine jams
does it jam up on the top or bottom?? if it shows on top it is the bottom thread if it jams on the bottom it is the top thread
Oct 12, 2009 | Husqvarna Viking 1
Sewing Machines Logo
173 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
