Question about Ovens
I have no power to the oven or ceramic hotplate when the power switch is on
Last weekend I had the same problem and the trip switch went and we found the the cooker had been wired with lighting cable so had that replaced. It has been ok all week but today once again there is no power going to it We have changed the socket and all seems fine
  • 960 Answers
If the cooker has been working on lighter gauge wiring for a long time and then worked for a short while on thicker cable, it may be due to a failing or failed element. With the bigger cable, its just been taking longer to trip out.
Posted on Apr 19, 2015
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
Cooking a roast in small oven last nite, all electric went, oven tripped it. Now no top oven working or main oven or fan. What has gone wrong?
When the mains fuse keeps tripping as soon as you switch on the oven, there could be a shortage in the oven, or some of the voltage is leaking to the ground. What it is causing it? I would not know. sorry.
Mar 24, 2015 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
When i turn on one of the hotplates it trips the electric out how do i fix it
Remove that hotplate. Reset the breaker and see what happens,
Other hot plates do the same?
Jan 28, 2011 | Ovens
4 Plate stove (hob), when switching on one of the plates it keeps tripping all the power. I have replaced the switch however problem persists. Secondly remaining 3 plates only seem to reach a low...
I would suggest you replace the hotplate that keeps tripping the supply, this hopefully will solve the prob you are experiencing with the other plates.
Sep 23, 2010 | Ovens
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Electrical output requirement for a buit-in oven and cooktop
Providing the existing switch outlet iscontrolled by a 30amp circuit fuse or trip, then there is no problem connecting the 2 appliances to the same switch.
If on the other hand, it is controlled by a 13 amp breaker, then you cannot connect both appliances to this, you would have to use 2 seperate sockets.
Hope this clarifys your question.
Mar 07, 2010 | Whirlpool RBS275PD Electric Single Oven
Hi, I am in the process of installing a new kitchen. I was recommended to buy Smeg appliances- an oven and ceramic hotplate by a salesperson stating they are very good aplliances, however another...
From experience I have found Smeg appliances to be very reliable.
It is difficult to judge reliability of appliances but generally these days NO appliance will last without some form of brake down. They are not made to the same quality as appliances of a few years ago.
If you stick to german made appliances (Bosch, Neff, inc Smeg ) then they tend to be built to a higher spec.
Regards
Aardvark Repairs
Nov 16, 2009 | Ovens
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
